Pioneer PDP-425CMX 42 in. Plasma Television Logo
Gregg Posted on Nov 16, 2007
Pioneer PDP-425CMX 42" Plasma Tv
The top 4 or 5 inches of the tv looks fine and below that there is a solid black horizontal line that is about 2 inches thick. From the Black line down, the screen is white with a little bit of ghost imaging. I plan on check the voltages at certain points on different boards, but before I start, I was looking for suggestions to see if anyone has seen this problem in any plasma before and can suggest a good starting point. I was thinking either the main board or the 42 x-drive assembly.
  • Gregg Jan 12, 2008
    The date of manufacture is December 2005. Thank you for your help.
    The date of manufacture is Dacember of 2005. Thank you for your help.
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Jan 11, 2008
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
29126
Points
37
Try the scan PCBs that run down the side and the connectors that hook them up to the rest of the system. That would be my first place to start.
Unfortunately I don't have service manuals for non-european models. What is the date of manufacture?
Only One HDMI Input Works
with hdmi plugged in take power cable out of apple tv ,put power plug back in then look to see if you have a signal....
2helpful
I see 11 flashing groups of about 4 ununiformely-doted lines (black and white) on my screen. Ech group of 4 lines is separated from the next by about the same width of the group (i.e. the screen is divided...
there maybe some problem with the vertical circuits with your tv, if you are still satisfy and tv is viewable then patiencely watch it. however as times goes by using it, if the defect is not corrected it may worsening the vertical circuits problem. scanning vertical trace is the problem of your tv.
The signal appears to buffer on some channels interrupting a clear video and audio presentation
When you are seeing buffering only on some channels then that is your cable provider or satellite. Nothing to do with your tv.If it were buffering on all then you can suspect something in the reciever section being annoying.
Pioneer plasma tv has vertical white line
Hi my name is Roety,
I can help you with your issue ,
 If the line is present on all inputs, and effects the menu the panel (screen ) is bad.
The cost of a new panel is probably more than a new Tv.
Try reseating the ribbon cables before trashing the TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
1helpful
Dpo adjustment
Press the menu key on the remote on on the tv itself. Look for the menu option that says "setup" or Video Adjust, or something of the like.  It should give you options like: color, tint, sharpness, etc.
Just browse through the menu to see how yours is setup.
Hope this helps.
enov8
1helpful
Pioneer plasma 42 inch tv won't turn on. power runs thru dvd. remote is sending signal and dvd has power.
There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
7helpful
Black line in a 42 inch panasonic plasma tv
I have a 2 black lines. One goes horizontal and one runs vertical. Is this something I can fix?
2answers
Akai pdp4298ed1
try lightly tapping the top of the tv where the bar begins. not on the glass but on top.
Black Vertical Bar
It will burn into the screen overtime. The Akai units have a resistor on the address board that feeds the PDP that usually has a crack in the solder on one or both ends of it. There are about 4 address boards that are right below the panel itself and the suspect one is the board right below the line that is appearing. Have someone with solder skills repair it.
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
