GE WBSR3140DW Top Load Washer Logo
Simon Gonzales Posted on Oct 19, 2015
Agitator coupler bell remove - GE WBSR3140DW Top Load Washer
1 Related Answer
Anonymous
  • 146 Answers
  • Posted on Nov 03, 2007
SOURCE: GE WPRB9220D Top Load Washer
There may be nothing wrong with the splie/gearbox shaft. At the top of the agitator on the inside is a brass "dog" That may be worn and you will need to replace it.
Wash machine ge space saver wsm2780hdwww agitator drive bell needs replaced have the part. problem is the old drive bell or hub is stuck inside at the top of the agitator itself. how do I get it out?
the agitator has to be pulled out manually the whole pc comes out from the bottom, place a rope or strong string under it and pull up hard. then u can remove the 7/16 nut and take off the agitator coupler or bell housing. , hope this helps
Wash machine agitator on my washing machine..?
the G.e style agitator just pulls right out and straight up but it may be difficult as it gets stuck often. once its out u can remove the screw the holds the drive bell coupler if u want to get the tub off u need a spanner wrench
Agitator only turns in one direction
Check the motor/transmission drive coupler for wear
I can not get the bell coupler off! I've removed the bolt and tugged as hard as I can but it won't budge!
yes sometimes that is the case,in my appliance repair career it has happened to me to,what i have done use a chisel and bust the agitator bell off, As long as you dont chisel it directly in the center damaging the transmission shaft the bell fits onto it should break apart after enough whacks at it.
Good luck,
Gene
My washers tub does not lock when in wash cycle. Tub spins in wash cycle. What could be the problem?
YOU MEAN THE AGITATOR IN THE MIDDLE OF THE TUB NOT MOVING AT ALL? IF SO, REPLACE THE AIR BELL COUPLER. YOU HAVE TO REMOVE THE AGITATOR TO GET TO IT. VERY CHEAP PART, UNDER $10. VERY SIMPLE JOB
[email protected] OR 714-334-1998
GE washer won't agitate!
if it's no agitation but it will spin remove agitator coupler or air bell
1helpful
My ge profile washing machine does not agitate. i need to know how to take the agitator off so i can see the coupling
remove agitator cap. if you cannot see a bolt. Ge uses a bell coupler....just pull up with all your might and it comes off. CAUTION: I've hit myself in the face, it hurts....be careful
1helpful
Agitator is slipping
I have a different model, but my agitator came off with brute force. I used 2 allen wrenches in the slots on the side of the agitator to get leverage and then yanked until it came off. The problem is your air bell coupler.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
