Question about Husqvarna Lily 540 and 550
How to get the hand look quilting stitch on the Lily 540
Which stitch selection to get the hand look quilting stitch
    Sergeant:
  • 248 Answers
Hello Joyce Smith
Please refer to page 45 in the instruction manual which can be downloaded for free at this link
http://manuals.husqvarnaviking.com/
Instead of using invisible nylon, if at all possible use invisible polyester thread. It behaves better and does not break during prolonged stitching. Use a "Quilting" needle size 80/12.
Happy Sewing
Sewingirl/
Posted on Mar 20, 2017
6ya staff
SOURCE:
stephen hillier
  • 16 Answers
SOURCE: husqvarna lily 540
bobbin wound too tight. remove thread first then pull off bobbin.
Posted on Jun 28, 2008
Anonymous
  • 87 Answers
SOURCE: Viking Lily - free motion quilting - thread loops on underside.
I need more info.
>Where is your presser fooot pressure set(1-9) it should be around 4?
>How fast are you free motioning (faster is better? from 1-10 10 being full speed.
>Is your bobbin threaded correctly (I need to cover the basics.)?
>Never never use a needle smaller than a 90/14 for free motion (I know everyone's an expert...but trust me)
After all this, it's OK to tighten your tension up on top a little when free motioning and getting eyelashes/spider webs on bottom. around 6 should do it though.
Posted on Mar 19, 2009
Norm Himebaugh
  • 152 Answers
SOURCE: Tension and missed stitches
It sounds like one of your clearances in the machine is off. When a machine skips stitches like yours is doing, it does so because the hook responsible for "catching" the thread from the needle is not close enough to the needle so it misses the loop of thread from the needle. If your machine was having a timing problem it wouldn't sew well on any fabric. A clearance problem shows up on certain fabrics at certain times. A few things you could do to try to compensate it would be to use a slightly larger needle and turn your top tension dial down to a lower setting. Move the machine a little slower on the frame or increase the speed of the machine. Either way a trip to your technician will be needed. Make sure you tell him to check the needle to hook clearance.
Posted on Oct 08, 2009
deborahcha
  • 371 Answers
SOURCE: How do I lower the feed dogs on my viking lily in
There is a switch the slides back and forth on the front of the machine at the throat below the needle plate but above the base (around the opening of the machine between the throat and the base). Slide it either left or right depending on where it is now. Otherwise, suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 14, 2010
Anonymous
SOURCE: bobbin does not wind all the way up
I have had this problem, easily fixed by twisting the rubber knob that is in contact with the spool to the left.
Posted on Apr 07, 2010
My machine is adding loops under my stitches when I try to stitch a straight stitch, I am trying to machine stitch a quilt top!
Quilting is a bit more finicky than regular sewing. Be sure to ALWAYS RAISE the presser foot when threading the top thread. FWIW, I use a separate bobbin case for FMQ that I have tightened the tension to keep the bobbin thread from coming to the top of the sandwich, but I tend to use a finer thread for quilting so adjusting the bobbin takes care of it. In your case, however, it sounds like the top thread is staying under the fabric. I would try tightening the top tension. Also, install a brand new needle--a top stitch, embroidery, or microtex needle seem to work well for me. Test well on a sandwich made of the same fabric and batting and get it adjusted well before sewing on your quilt. Sometimes sewing speed will affect stitches under the fabric, or even on top.
5 Free Motion Quilting Problems and How to Fix Them
Correcting Sewing Machine Tension for Free Motion Quilting NQC
LOOPS Tension or Speed
https://www.generations-quilt-patterns.com/machine-quilting-thread.html
https://www.generations-quilt-patterns.com/sewing-machine-tension.html
https://www.generations-quilt-patterns.com/machine-quilting-tension-problems.html
Feb 27, 2018 | Sewing Machines
How to get the hand look quilting stitch on the Lily 540?
Hello Joyce Smith
Happy Sewing
Sewingirl/
Oct 19, 2015 | Husqvarna Lily 540 and 550
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
Do i have adjust tension when free motion quilting on janome 6125
No but need free motion foot, FMQ is A bit of an art, slow hands and even stitching. Doing a class is a great way to learn as stipple quilting looks great but takes practice.
Feb 28, 2015 | Janome Sewing Machines
Does a husqvarna sew easy 330 have quilting stitches?
it has several stitch selections including straight stitch, zigzag and multistitch zigzag. What stitches are you looking for?
Jul 03, 2014 | Husqvarna Sewing Machines
I want a longer straight stitch (mine only goes up to 5) on Janome MC 4900, to mimic hand quilting look.
There are several models of machines that do a longer stitch, usually called a basting stitch. Unfortunately, your machine does not have this function. If you are looking for a machine that will give you a hand quilted look, the Baby Lock Sashiko can give you that, though it doesn't do anything else.
Feb 26, 2014 | Janome Memory Craft 4900QC Mechanical...
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
Sep 19, 2009 | Husqvarna Freesia 425
Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Apr 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Stitches
Usually a walking foot is for straight forward stitching only.It keeps the many layers from shifting for you. The "hand-look" quilting takes a couple stitches forward then one back. If you look close, you will see about every other stitch is thicker and stands out more.
Jul 25, 2008 | Brother CS6000i Computerized Sewing...
Sewing Machines Logo
67 people viewed this question
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
