When I turn the camera on in Manual mode, it shows a black screen with the icons but no image. When I turn the camera to Auto everything works fine. How can I fix this?
Dear Olia,
Just a quick check on your camera. You have a focus issue so check the settings for the ISO - increase the value, eg. 800 or above and reduce the shutter speed. You can do that by the quick access dial (wheel) facing you. There are four direct access menus in a criss-cross direction. One is assigned to shooting mode - single, multi, timed etc. The other direction will have macro, standard, telephoto etc. the 3rd direction will (towards right) will take you to the ISO settings and the last will take you to the shutter speed settings.
you manipulate the ISO and shutter speed and see your screen will brighten up and the subject will be clear. Refer to the picture attached.
Hope this helps.
SOURCE: Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
SOURCE: Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
SOURCE: Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
SOURCE: Canon PowerShot SD780 IS camera lens error. :(...
I did the same thing and it works only be restarting it now but it works lol. I threw it agianst my bed . SO BEAT THE **** OUT OF YOUR CAMERA..then restart and it should work..*** made **** what can you say
SOURCE: My camera will no longer show the image on the
most likely you have turned the dispaly off. find the display key and turn the screen back on.
another option is to go into the menu, then go to display and set it there.
