E30DF74GPS2 Electrolux Icon dual fuel gas range 30
Hey Scott, I understand that you are having problems with your Electrolux Dual-fuel Range. When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
SOURCE: How to clean lower oven of 30" electric range by electrolux
try a lemon heated and the acid will eat away the food
Sounds like the control board to that element has a communication error or a loose connection. Contact a professional to be sure.
SOURCE: electrolux dual fuel oven will not heat after self clean
The unit needs to be reset. The temperature had tripped the internal sensor of the unit. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside.
Hey Troy, I understand that you are having problems with your Electrolux Dual-fuel Range. Have you recently installed the range or had a power outage? When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
