It seems to me that the water pump is not emptying fast enough that seems that there might be something stuck in the pump clogging the outlet,first of all turn the machine off blow down the outlet pipe,if you cannot blow into it then remove the back cover and remove the pump housing to remove the blockage,resemble and there should be an improvement in the spin problem
If it is a F18 error,t means that the pump out time is too long. Most likely clogged filter.
Open panel on the bottom right, drain the water out using the left hose and remove the filter plug. Have a look and clear obstructions.
That should help.
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
