Recess Dimensions are: Height - 580 mm Width - 560-570 mm Depth - 550 mm
SOURCE: What is a replacement microwave
You can contact Sharp at
1-800-BE-SHARP (1-800-237-4277) or visit them online.
They should be able to recommend a "drop-in" replacement.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: My father's old Jenn-Aire microwave, Model # M170,
You can contact Jenn-Air customer service and they should be able to tell you if there is a "drop-in" replacement for your model.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
Testimonial: "Thanks for the quick reply and helpful tip. I will follow up on your suggestion."
SOURCE: What are precise height. width and depth of Amana
We would need the full model number to tell you the dimensions. You'll need to post a new info request with model number.
If an oven is arcing, it's almost always grease and/or food particles on or behind the waveguide cover, turntable coupler, or elsewhere inside. A good cleaning is usually all it takes.
SOURCE: Need a replacment microwave oven (black) for a
Pretty easy to change.Maybe cash and carry would be a little cheaper, or even trying an appliance dealer to see if they can get the same thing. Perhaps contacting manufacturer of microwave directly will help. (www.dometicusa.com) There was some recalls on some of the models. Are you sure it's not just sitting in an opening above the range hood. Most are just 4 screws or so, and out they come from opening above that.
SOURCE: Thanks for your help. I have a micro/oven combo,
I too need to replace my microwave in the RM288PXV....is that possible?
