When you set the timer see if PDC appears. If it does switch it to off and try setting a record. PDC sometimes doesn't work. And the recorder will sit there waiting for the signal to tell it when to start recording. Which never comes! However you will have to set the time to adjust for it not recording late running TV shows. For example a show to start at 8pm and finish at 8.30pm, will need to be set at 7.59 till 8.35pm. Or you could miss the start or end! Wheras PDC would get it all even if it started at 8.05!
Your Digital Voice Recorder has no on/off button or switch.
Just make sure you press the Stop button after you finished using it, to stop any activity.
You are probably having an issue with the discs rather then what you are trying to play them on.
The discs need to be finalized before they can be used on another player.
Put the disc in the drive (the ones you have already recorded)
Press SETUP on the remote
Select - Disc Edit Press OK
Select - Finalize Press OK
Wait until it is finished then try to play them on another player.
Here are instructions on how to use recovery mode procedure to make the mp3
player turn on. Do the following steps:
1. Turn player off. Hold the power button down for 20 seconds to make sure
it shuts down then put the "Hold" switch ON. The Hold switch is located at
the top part of the mp3 player. 2. Now hold the "Record" button while you connect it to the computer. Keep
holding it until it finishes installing the new device.
Are you talking about recording from the list? You might have to set the recorder to record chanel 3. I can't check it because my dvd recorder is broken. I haven't done it in a while, I remember going to list and telling tivo to record to vcr and recording chanel 3, but you can't watch tv till it's finished.If you are talking about a connection try an a/b switch. All I can say is experiment
