Why is my 55 inch rca turning on by remote but not off, then saying please run channel scan but I can not get it to do anything but turn on. It is brand new out of the box yesterday.
SOURCE: RCA Colortrak 2000 remote control
I called RCA's 800 number on the back of the owner manual--got a response that said to replace the unit since only the up-down channel changer buttons were not working. Using another remote (universal) now--cost only $5.
SOURCE: rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
SOURCE: RCA L32HD31R/Dish Network Remote Code Problem
The word from RCA technical support is that the remote for the L32HD31R operates on a different frequency and there is currently NO universal remote on the market that will work with the set. They say that they have plans to market a universal remote and that they are working with other manufactuers of remotes but there is no resolution or time frame available. In short, you will have to use two remotes and keep checking the RCA website for a breakthrough.
I'm not sure that I would have bought the TV if I'd known.
SOURCE: rca l32wd22 blackscreen
princess_dc6,
Just recently, I was told how to get another tv.
You find a good TV service centre and ask them to fix it. If they cant you take the work order from your tv sc and call 1-877-297-8391.
You will get yourself a tv
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
