Question about Proscan 10.1-Inch Internet Tablet, Capacitive Touch Screen, Android 4.0 with Front Camera, 1.2 GHz, 1 GB RAM"
How to update Google services it stopped working
I resetted my tablet and now the Google Play Store system keeps stopping and I can't access any apps
Try update your google services go to settings then apps go to google services and try and update it if there's software update available
Mar 17, 2018 | Tablets & eReaders
How do I get google play services on a nextbook tablet
Have a read of these and the video links in the main link at the bottom.
2.1 eclair - How do you fix your tablet if Google Play Services is ...
android.stackexchange.com/.../how-do-you-fix-your-tablet-if-google-play-services-is...
  1. Cached
  2. Similar
Nov 1, 2014 - How do you keep Google Play Services from stopping or get it to start back up? ... it instantly said "Google has stopped" so I reset the tablet by sticking a ... google-play-services nextbook-premium-8 or ask your own question.
How can I download Google Play to my Nextbook tablet? - MakeUseOf
www.makeuseof.com/.../how-can-i-download-google-play-to-my-nextbook-tablet/
  1. Cached
  2. Similar
Dec 27, 2012 - I bought a Nextbook tablet running Android, but I can't seem to get Google Play to download to it. The sales associate told me that Google Play ...
Google Play services - Android Apps on Google Play
https://play.google.com/store/apps/details?id=com.google.android.gms&hl=en
  1. Cached
  2. Similar
Rating: 4 - ‎10,084,970 votes - ‎Free Google Play services is used to update Google apps and apps from Google Play. This component provides core functionality like authentication to your Google ...
This app won't run unless you update Google Play services · Issue #37 ...
https://github.com/google/iosched/issues/37
  1. Cached
  2. Similar
Aug 15, 2014 - Update Google Play Services message on nexus5 with Android-L and ... Can someone please help I have a next book 7.85 tablet and the the ...
Unfortunately ,Google play services has stopped. - Google Product ...
productforums.google.com/d/topic/play/fqU5vZlybGk
  1. Cached
  2. Similar
Sep 20, 2015 - 100+ posts - ‎82 authors When I uninstall the update to Google Play Services the tablet immediately notifies that Google Play Music won't work without it, Google ...
How to Fix Unfortunately Google Play Services Has Stopped Problem ...
forums.androidcentral.com > Get Help & Give Help! > Ask a Question
  1. Cached
  2. Similar
Dec 27, 2015 - 14 posts - ‎11 authors Friends, I rooted my Moto E xt 1022 & the problem started. I tried different solutions suggested in the post, but could not fix. I also restored. google play services on nextbook tablet Google Search
Jan 06, 2017 | Nextbook Tablets & eReaders
Google play wont load on the tablet. I cant connect to google at all. what should I do?
Go into settings (not google settings) scroll through apps, open up google play, delete cache and updates, restart and go to play store to update.
May 15, 2016 | Tagital Tm 9" Android 4.0 Tablet PC...
The Google play services are not working on my Tablet, how can I fix this?
Google Play Services needs to be updated from time to time. It seems to keep getting bigger and bigger. You can go into Settings - Apps and then ALL and scroll to find Google Play Services and then click on it. The screen that comes up will give you the option to clear the cache and clear the data.
First clear the cache. Then see if that solves the problem. Likely it won't. Then you can clear the data. It that doesn't work for you then click on *uninstall updates.* This will reset the Google Play Services to original factory. Reboot and make sure you have a good wi-fi connection as the Google Play Services should connect to the Google Play Store and update automatically. If it doesn't, then open the Store app and select *My Apps* *All* and scroll to Google Play Services.and click *Update*.
Note: the Store App, itself, might be slow and balky until the updated Play Services is installed and running.
Here's a hint. If you do the above and delete the updates from the Google Play Services app on your device, when you boot up your device might act balky - just give it a few minutes as it's probably connecting and downloading the Google Play Services updates automatically. Google Play Services is important for just about everything that communicates with Google so don't expect all the other Google apps to work until the updated version of Google Play Services is installed and working.
Mar 08, 2015 | Tablets & eReaders
Why do my Google play services are not available on my tablet?
1. Remove the updates for your Google Play
- Go to the menu->settings->apps->all->google play store-> uninstall updates, then reboot your device.
2. Remove the cache for your Google Play
- Go to the menu->settings->apps->all->google play store-> remove cache, then try to run your google play again. It is better to do a reboot.
3. Try to delete and re-install Google Play
- In some cases, delete and re-install resolve this issue.
4. Try to delete your google account and add your google account again
- Go to the menu -> settings -> account remove your current google account then add it again here.
Mar 02, 2015 | Tablets & eReaders
Why did google play store stop working on my NuVision Android tablet? It was working fine.
Try to uninstall updates of play store.. Settings>apps>Google play store>uninstall updates..
Feb 11, 2015 | Tablets & eReaders
Google play services has stopped workimg & locked up m hkc tablet
Try and delete then re install the app. If it's a system app just uninstall the updates. See if that gets google play working again. Reboot after you uninstall and see if that helps.
Aug 18, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Update google play services?
Go to Settings -- Device -- Apps -- Running and scroll to Google Play Services (there may be more than one), then press it. You should see each service listed as running (it'll have a Stop button below each one). This means it updates automatically;, you don't have to do anything.
Aug 12, 2014 | Samsung Tablets & eReaders
Proscan 10.1-Inch Internet Tablet, Capacitive Touch Screen, Android 4.0 with Front Camera, 1.2 GHz, 1 GB RAM" Logo
59 people viewed this question
Top Proscan Tablets & eReaders Experts
 Mike M
Mike M
Pollo
Level 1 Expert
Harrie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
