Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
y
yolanda smith Posted on Oct 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why my alarm wont come on when door is left open
My door was left open and the alarm never did go off what is the problem
Muhammad Shahbaz Anwar
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 37 Answers
  • Posted on Oct 15, 2015
Expert
Level 2:
New Friend:
Greenhorn:
Answers
37
Questions
0
Helped
11153
Points
103
There is a short circuit in wiring. please check its wiring
1helpful
Hotpoint FZFM171 freezer door left open all night, has defrosted and the 'super freeze' light and alarm light wont stop flashing. How do we fix it?
Turn the power off to the refrigerator and manually defrost the freezer until the freezer bis no longer cold and then replug the power cord
.APPLIANCE 911
1helpful
Panic alarm does not work. Locksmith verified that it is not the remote fobs.
central timer module" - Dodge Dakota Forum
www.dodgedakota.net/boards/gen/21983.html
Jan 2, 2009 - 21 posts - ‎18 authors
I have a Dak 2000 3.9 Ltr V6, Single Cab, Bare Bones. ... Panic Mode .... ooops....i mean the remote entry and alarm system does NOT work ... i have a 2002 dakata where can i buy a ctm looked all over nobody sell them can thay be rebuilt ... I was out the door $550.00, and they washed the truck also.
Truck wont work/Key Fob won't work/wont start/wont do anything ...
www.ramforumz.com > ... > Electrical
Apr 10, 2010 - 10 posts
Truck wont work/Key Fob won't work/wont start/wont do anything! ... Maintenance & Repair > 3RD Generation Dodge Ram - 2002 to 2008 Dodge Ram Trucks > Electrical... Soon as I manually unlock the door, and open it.... the factory panic alarm starts going off. .... Vehicle: 2004 Dakota Club Cab 4X4.
alarm going off when opening the door.. embarrassing and annoying ...
www.cumminsforum.com > ... > 3rd Gen. Non-Powertrain
Jan 12, 2012 - 11 posts - ‎9 authors
how do I stop my trucks alarm from going off when I open the door? it did it ... to thetruck and opened driver door (it was unlocked) and the alarm started going off. ... I do not have a remote unlocking device (or it doesnt work) so I do all .... alarm will go off then I have to use the FOB panic button to shut it off.
Keyless entry/panic button/alarm - Dakota Durango Forum
www.dakota-durango.com > ... > Gen III Dakotas
My 98 kia sportage wont start
It sounds like the key sensor in the drivers door is malfunctioning, the drivers door is the only door that can enable/disable the alarm, if you try to unlock any of the others it will trigger the alarm.
Sometimes with my Kia I have to (without opening the door), cycle lock and unlock several times before the alarm is disarmed.
Have you tried this is succession, with all the doors locked:-
put the key in the drivers door, turn to lock and then to unlock, the alarm should disarm.
Also, if any of the door locks are jammed, the alarm will still activate when you try to unlock the drivers door.
If that fails and the alarm still activates, then it's a problem with the key sensor in the door.
6helpful
3answers
My 1998 dodge intrepid wont start and the alarm wont shut off
Try "cycling the key in the passenger door lock. Turn it all the way to the right and all the way to the left.
Refridgerator E249T the beeping alarm wont stop. The door appears okay. How can I disconnect the alarm, please? Thanks Brian
I have the same fridge. It was driving me crazy. I emptied it. Cleaned it. Defrosted it. And was ready to dump it. Then worked it out. As it beeps when the door is open. How does it know. Because when the door is open the light is on. I taped up the light nob with masking tape, on top left of fridge. No light now
But no beep Yay!!!!
Left solstice in garage 6 months when i whent to open door battery was flat had to open door with key manualy alarm whent off since then car does not drive well any sugestions
Hi
Have you put new fuel in the car? fuel left for 6mths wont be very good. and most likely will need a service, new plugs etc etc, change the oil and check the battery connections.
Hope this helps
Regards
Dan
3answers
1997 Honda Civic: Battery died and the Alarm won't disable
If you hook up the jumper cables can you disable the alarm with the remote?
2answers
Back door wont open after can went dead and had to get a boost
try checking the fuses for the swithes themselves, usually under the dash or beside the doors
My doors wont open
disconnect the bonnet switch under the hood behind the right headlight .should stop the alarm.let me know how you get on with this.will the doors open manually with key in door.or they wont open with remote as you did not specify
2answers
Lost keyless entry remote
The fuse for the alarm is under the hood. Give a good look and you should find it. Once you have pulled it it will deactivate the alarm I am not sure if this is exactly your problem since you said that the car wont start.... but it is worth a try.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
