Your old valve plate can be repaired. Usually only one or two reeds break. Carefully trim off broken reed exposing port hole. Tap hole with fine thread and make plug with proper matching bolt. plug should be same thickness as plate. Thread in plug using thread locker then ping in several spots. Works without loss of volume. You could also replace the reeds. Good luck..
