Chromecast works fine with VHD-H1x4si but when amazon firestick is connected, it keeps restarting. It might work for a minute then gives static sound and restart. Amazon firestick works fine when directly connected to HDMI on tv but when connected to VHD-H1x4si hub it keeps restarting. Please help. I can be contacted at 917.847.0222
Suspect the firestick may be getting weak signal from the router.
Testimonial: "amazon firestick works fine by itself when directly connected on tv through hdmi port, but when connected via hub it keeps restarting. please assist. Is there a number I could call you at?"
the firestick looks for signal from the router (wireless). i suspect that the firestick receives better signal from the router when directly connected to the tv (physically at a higher elevation, signal from router is not obstructed), than when connected to the hub. when you connect the firestick to the hub, suggest you locate the firestick such that it could receive a better signal from the router.
physical location of router with respect to tv & hub?
