Apple iPod touch Logo
Anonymous Posted on Jul 13, 2009
Can't unlock my iPod Touch!!!!
I cant unlock my iPod Touch becuz whenever I try to type in the passcode, it dosen't show up, please help, all I can do is listen to music!!!
PS> Ipod Touch 2nd generation, 16GB--pls help!!!!
  • Anonymous Jul 14, 2009
    nah, i didnt need to do that, i figured it out, it was quite simple actually, what i did was pressed the home, and sleep button at the same time,and the iPod system rebooted.....NOTE: this doesn't delete your music, apps, videos..etc.
Anonymous
Level 2:
  • Expert 82 Answers
  • Posted on Jul 13, 2009
Anonymous
Expert
Level 2:
Answers
82
Questions
Helped
35129
Points
150
U r screwed up. get help from mac people.they have utility to bust it
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
How do i unlock my ipod touch
Hope it helps
My Ipod touch is currently disabled and when i tryed to connect it to itunes it said it won't let me do anything to the itouch until I unlock it. The problem is I have no way to type in the passcode. Can...
Yes. You can't do anything unless you type in the correct passcode. But there's a way to bypass that lock, and you can learn how by reading this tip:
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: [email protected]
1helpful
My Ipod touch is disabled Please HELP ME
If it was locked and you donot know the password then the only thing you can do is restore it using dfu mode hold both power and home button until it turns off and restart and show you to connect to iTunes2_bing.gif. Then restore it. Let me know what happened.
4helpful
2answers
FORGOT PASSCODE
If you can't remember your passcode, you will have to use iTunes to restore you Touch. Remember that restoring will erase eveything on the Touch, make sure you have made a backup of your data first.
Here is detailed steps on restoring:
http://support.apple.com/kb/HT1414
5helpful
4answers
My 8gb ipod is locked and i cant unlock it
cant unlock my ipod touch code i forggot my passcode
My ipod touch is locked and disable i dont know how to unlock it
  1. Connect the iPod to your PC using a USB cord.
  2. Open iTunes.
  3. Click the Options button in the lower right corner of the iTunes window.
  4. Click Enable USB disk use. (sometimes optional)
  5. Go to "My Computer" and select your iPod.
  6. Select tools and the folder option.
  7. Select the "view" tab.
  8. Select "Show hidden files and folders".
  9. Search for the file (file name differs in earlier versions) but on all models it will be located in the "Ipod_Control" folder aka Settings
  10. Look in a folder that is sometimes called "Device" find a file named "_locked".
  11. Change the file name "_locked" to "_unlocked".
  12. and listen to the good old tunes"
From
wikiHow
Check also
Unlock iPod Screen "
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
