Question about Brother DCP 115C All-In-One InkJet Printer
How to fix a error message
Message says unable to init
6ya staff
SOURCE:
Mix-it-up
Mix-it-up
  • 832 Answers
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Posted on Mar 13, 2008
Anonymous
SOURCE: Error 46 Unable to Init.
No need for part necessarily
SkipperOz solution pasted below
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Posted on Apr 10, 2008
Anonymous
SOURCE: i have an error called "unable to Init. E3". how do u fix this?
Go to menu, network, restore factory default. The printer will restart. Then reset the WLAN per your home connection.
Posted on Jun 07, 2009
Eric Sandbo
  • 159 Answers
SOURCE: Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Posted on Jun 11, 2009
Anonymous
  • 60 Answers
SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Posted on Feb 03, 2010
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
How to fix Error message ..Unable to init.4F ?
Sorry... Print head damaged. There is an very low possibility to erase the error without buying new print head, but it's unprofitable
May 18, 2014 | Brother MFC-J415W Multifunction Inkjet...
Init unable 34 message
Printhead not moving. Check for any thing blocking the head or anything stuck.
Apr 10, 2014 | Brother DCP-J140w Compact Color Inkjet...
My brother mfc 495cw keeps giving an "unable to init." error message. chris.iya@lausd.net
Hi. my machine model MFC 495 CW. I did any step but my machine till show up unable to Init. 4 F. please can you help me about that. thanks you very much
Tien
Sep 07, 2010 | Brother MultiFunction Center MFC-440CN...
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
Jul 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
Unknown error message UNABLE TO INIT. printer just stopped working
Mar 13, 2008 | Brother MFC-620CN All-In-One InkJet...
Error Message "Unable to init 46"
error 46: waistink absorber needs replacing. you must have run quite a lot of manual cleaning cycles in case your mfc is about 1 year old....
Feb 26, 2008 | Brother MultiFunction Center MFC-440CN...
Unable to init error message and and machine error 4f
i can not print any documents it keeps coming up as Init unable 4f please help ?
Sep 27, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
94 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
