SOURCE: Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
SOURCE: I have a leaking Delta bath faucet. It?s a model
Well, even with the main valve off, the lines are still pressurized and still populated with water.
SOURCE: Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
SOURCE: adjust the hot & cold water for delia monitor 1700
Remove handle and check to see if there is a dial to take out to repostion back in to adjust cold and hot water flow. take it out and move it a little put handle on and turn on see if it changes,
