Sign into Facebook get white screen, Using AOL, IE, Chrome and I even tried my IPAD. Thied IPAD at Starbucks same problem.
Https://gethuman.com/phone-number/Facebook
650-543-4800 Facebook phone support
SOURCE: Cannot log out of Facebook
The solution I found is simple...
1) Go to the "Tools" option in InternetExplorer
2) Then go to "Internet Options"
3) Select the "Delete" option in the browsing history section.
4) Menu will appear, simply UNTICK THE FIRST BOX! which states "Preseve favourites website data".
This will remove the facebook cookie and stuff so when you log out of hotmail you will not see that message about not being able to log out of facebook anymore =]
Hope this helps It really should!
SOURCE: I cant access www.facebook.com or just
your account might be corrupt or disabled. contact facebook.
SOURCE: I can't sign up in facebook, even try to set new
Clear your cache and delete all of your cookies in your browser. In your browser, type in the address bar http://www.facebook.com/login (which doesnt exist).This will take you to a different login page which reads: "The page you requested was not found."
At the top of this page is a login box. Try using this login box to login to facebook. If you are using the Adblock extension with Firefox, and subscribe to an ad list (basically a list of known ads online), it blocks a special site (fbcdn.net) that Facebook uses to login.
Go to: http://www.facebook.com/login.php (the page you are having trouble logging in) and click on the
Adblock Stop Sign on top of Firefox, and you will see in red a url that includes fbcdn.net. Right click on that, and add an exception for the entire fbcdn.net domain. Reload the page. This should fix the problem.
You can also use a Proxy Server to connect to Facebook.com. Search Proxy in GOOGLE,select Proxy Server and type in facebook.com (in the proxy server webpage).Finally now you can login into your facebook account.
Thank you!!
SOURCE: cannot get into my account
You just have to sign out your grand daughter's account.
On the top right corner of your facebook page, click "account" then simply click "logout".
Hope this helps you. Thank you for using fixya.
P.S. Please rate me :)
SOURCE: I' ve been trying to login into my facebook
From Facebook:
If the login email address that you normally use to log in to your Facebook account is still associated with your account:
https://ssl.facebook.com/help/contact.php?show_form=hacked_self_recovery
If the login email address listed on your Facebook account has been removed by the another person (i.e., someone has replaced your login email address with one that you do not control):
http://www.facebook.com/help/?page=1024#!/help/contact.php?show_form=hack_login_changed
There are two indications that your login email address has been removed by another person:
To solve this issue on your own, please look for an email at your login email address with the subject "Facebook Contact Email Change Notification" and follow the instructions to cancel the email change.
