Compressor Support
Home Use:
Compressed-air power tools can dramatically decrease the amount of time spent on a project. Many homeowners will use smaller, portable units (either hand-carried or wheeled) that move easily from the garage to the house, yard or roof. Common air toolsAir Tools such as brad nailersAir Nailers, reversible drillsAir Drills, and impact wrenchesAir Impact Wrenches require about 0–5 CFM (Cubic feet per minute — units in which air flow is measured). It's important to know if the compressor you purchase will drive the air tool you'll need for your project. For example, smaller air nailersAir Nailers run on 2 to 5 CFM at 70 to 90 PSI, while larger shearsShears, sandersSanders and polishersPolishers require up to 10 or more CFM and 100 to 120 PSI.
Business Use:
Air compressors used for business/professional applications are often classified “industrial grade.” They're packed with features that let you take on more demanding jobs with more horsepower, more CFM, more PSI and more (longer) run times. Though some industrial-grade compressors are portable, many are stationary units with large-capacity, ASME certified air tanks (up to 120 gallons), greater HP, more CFM air volume and faster recovery time to run a wide variety of air tools for as long as you need them to do the job.
