the error code appears when a tension arm (front or rear) of the ITB tension roller is broken.check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041. To clear the error: * 2 8 * COPIER FUNCTION CLEAR ERR OK Turn off and on ( main switch )
Go to functions = clear errors -- first 3 errors in clear list.
Press reset .
Now just tighten the connecting cables of machine.
Star the mc
