Contributor
- Posted on Oct 08, 2015
Re: can I link audio out from one to another?
- From the Finder, choose Utilities from the Go menu. Open the AudioMIDI Setup application.
- Click the Add (+) button on the bottom-left corner in the Audio Devices window and chose Create Aggregate Device:
- A new aggregate device appears in the list on the left side of the window. To rename the device, double-click it:
- With the new aggregate device selected, enable the checkbox labeled "Use" on the left side of the Audio Devices window. Do this for each device you want to include in the aggregate device. The order in which you check the boxes determines the order of the inputs and outputs in applications like Logic and MainStage. For example, the first box you checked will be inputs one and two, the second box checked will be three and four, and so on.
- To use the clock of a device as the master clock for all the combined devices, choose the device from the aggregate device's Clock Source pop-up menu. Choose the device with the most reliable clock:
- If your audio devices all work with word clock, connect them together using a word clock cable. Connect the cable from the device you designated as Clock Source in step 5 to the input of each other device. Refer to your audio device product documentation for specific details.
- If any of your devices do not work with word clock, enable the Drift Correction checkbox for the devices that are not designated clock master.
Testimonial: "Thank so much, but I don't know where is the Finder?"
