Standby light stays on but TV will not turn on . Checked power source it works. My alarm clock works in both plug ins how do I get the TV on?
Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
SOURCE: power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
SOURCE: JVC Model AV-36D502 Blinking power light on start-up
you probably have some sort of overheating or short on the internal board - is it still on warranty? if so they will fix at no charge - if not, a local repair shop should be able to correct the problem but it may cost as much as $150
SOURCE: Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
