Lens comes out when power is pressed but lens won't retract when power is pressed, lens retracts when battery is removed
SOURCE: Olympus FE-210 lens does not come out
Hey memiche,
You could try resetting the camera to the default factory settings, and directions on how to do this are on page 20 of your camera manual. If this doesn't work then there is either something obstructing the movement of the lens (i.e. sand), or damage to the lens mechanism. If it is something obstructing the movement of the lens you could try blowing compressed air into the side of the lens to try and dislodge whatever is in there. If that doesn't fix the problem you could try putting the camera on a flat surface with the lens pointing up and holding in the shutter button, and while doing that turn the camera on. If none of this works I would have the camera looked at by an authorized service technician. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.olympusamerica.com/files/FE-210%20Advanced%20Manual.pdf
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: FE-170 - Lens extends & retracts 3 times when powered on.
appears to be power issue in the camera but you can try the lithium AA batteries that are located in the photo section of your stores... they are more powerful than regular AA batteries or else send to repair shop
SOURCE: the lens won't retract
If the lens is stuck out extended you may want to call Olympus Customer Service to discuss repair process and pricing. If the battery is fully charged and the lens still stays extended then this is a clear repair issue as something in the lens assembly has failed. Their telephone number is 800-622-6372 option 2 and then option 3
SOURCE: Camera malfunction
I had a Nikon Coolpix L1 with a very similar fault- the lens would whirr in and out as if seeking then lock either in or out with a 'lens error' message.
Not sure you're going to like the solution: place a paperback book on a strong table, grasp your precious camera firmly in one hand and slam its flat base down as hard as you dare onto the book. Hold it hard to the book as it touches, don't hit and lift up again; more slam effect.
I tried this and it worked beautifully; for a few months. I had to do it once or twice a year.
I got the suggestion from a site similar to this with 10 or so astonished owners who had tried it and couldn't believe it had worked so well!
Aren't digital cameras ****, though? I may go back to 2nd hand 35mm SLR for something that actually works!
SOURCE: My Olmpus fe-360 wont turn on. The lens won't
Your problem may be due to weak/worn out batteries
or corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the
batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, your
batteries may need to be replaced, or the camera may have
a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. A "Very Helpful" would be greatly appreciated.
