Casio Brand New-Fx-991es Plus - Scientific Calculator Logo
katrina nahhas Posted on Oct 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I insert a root on my calculator (for example sure root of 180) it gives me the answer in decimal places... how can I make it give me the answer in surd form
paulgbrandon
Level 3:
  • Casio Master 661 Answers
  • Posted on Oct 07, 2015
paulgbrandon
Casio Master
Level 3:
Answers
661
Questions
0
Helped
189451
Points
1916
Looks like <Shift><Mode> <down arrow> <1>
Give it a shot. I have attached the manual.
Good luck.
Paul
http://support.casio.com/pdf/004/fx-115ES_991ES_Eng.pdf
1helpful
When I raise a number to the power of a fraction my Casio calculator shows a decimal answer, what setting will put it in surd forms instead?
Change the output display to MathIO. You may be able to display square roots only: so no cube roots, nor fourth...
The calculator does not show decimal when square rooting non-prime numbers. (fx-CG20)
You should feel happy that your calculator can perform some exact calculations. If you do not want the exact values you can press the SD key. You can also press SHIFT EXE rather than EXE alone.
Not giving proper awnsers for square root questions
Contrary to what you believe, results with square roots are exact. Decimals are approximate.
Press the SD key to convert from standard to decimal representation.
Casio fx-82ms calculator does not give me an answer when i use the percentage button . example if i type 0.25/ 100% i get 0.25 instead of the right answer 25
Here is a sample of the percentage calculations that the calculator can perform. You will not see among them the conversion from decimals to percentages.
To convert from decimals to percents move the decimal mark 2 places to the right and append the % sign.
To convert from percents to decimals, move the decimal mark 2 places to the left.
4answers
On my casio fx-82au plus calculator it won't
The capability of these calculators to handle irrational numbers in radical form is limited to square roots. Roots of index other than 2 are always displayed in their decimal representation.
If the calculator IO mode is set to MathIO, square roots will be displayed with the radical symbol. More complicated expressions with square roots might not be preserved and will be given as decimal numbers.
When I enter the square root of 7 and hit enter it just repeats that and shows square root of 7. How can I get the exact answer?
Instead of hitting enter, hit diamond, then enter. The calculator will then give you a decimal approximation. Alternatively, you can go to F2, approx( and enter in the root you need approximated. Another method is to go to the MODE page and scroll down to Exact/Approx and change it to approx. That way it will work the same as a TI-83/84 and always give a decimal answer.
I have a T1 30xs, and I am trying to figure square roots. It picks and chooses which square root it will give me. For example. it will give me the square for 729 and 64, but all it will do for, say, square...
The calculator is able to display fractions and certain irrational number as radicals. However there is the twosided arrow key to
toggle between exact and approximate (decimal).
Here is a screen capture from the manual to give you some more informations. k24674_127.jpg
How do I find the square root of a number? and how do I enter scientific equations?
For square roots, use the square root key just to the left of the divide key. For example, 4 square-root = will give you 2.
The calculator doesn't have any way to store equations, scientific or otherwise. If you mean scientific notation, use the EE key just above the 7 key to enter exponents. For example, to enter 1.23x10^6, press 1 . 2 3 EE 6. For negative exponents, make sure to use the +- key to the right of the decimal point instead of the - key.
3helpful
When I divide the answer is in fraction form not decimal form how do i get it back
There are two options.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers.
For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
