Eric, the one thing I can think of is that either your linkages are incorrect, by that I mean it sounds as if then you throttle it up, it gets stuck open... I would go over the carburetor set up and make sure that everything is correctly back in its right order.. you may also have the governor set too high, adjust it lower if it sounds as though the engine is working too hard or screaming.
SOURCE: Throttle doesn't work properly
try sears.com go to parts and enter your mod# from under your seat IE:358. and so on.
Look around for prompts and info for you mower from your entered mod#
SOURCE: throttle stuck wide open and cable is all working
that's what it is alright the linkage either got bent or there is grass or maybe a stick got caught in there but what ever the reason you must get that fixed or your mower won't last any longer..good luck
SOURCE: I have a Husqvarna iz4817
was stored with fuel lines not being drained/ bad fuel, you can try a fuel cleaner it may take a few times to clean out the tarnish that forms when gas is left in tanks that set and don't run for periods of time. hope this helps Tim
SOURCE: What would cause my 17hp Kawasaki engine to run
see if the linkage is binding if not you will need to open the engine and check the gear
