Repair your vehicle right away. Just click on the link I attach.
JOHN DEERE D140 SERVICE REPAIR MANUAL
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
SOURCE: need diagram for la130 john deere belt replacement
is it a 42" or a 48"
The above is for a 42"
this is the lower cutter belt also the drive belt to the g/box is different
SOURCE: Replacing traction drive belt for John Deere L118
Actually this is a fairly easy looking one to replace. If you go to John Deere parts and do a search for your tractor, in the parts listing it gives a pretty clear picture of the routing and configuration of the belt as it should go on, you might want to print it out to have nearby while you are working on it. You will need to remove the mowing deck to get at it and possibly some large blocks to elevate the tractor to give yourself room to work.
Look closely at the old belt if it is still on the tractor to get an idea what is involved BEFORE you start, comparing it with the picture. You will need to loosen and move or remove the belt guards and do be careful of the nylon fan on top of your transaxle
SOURCE: i need a belt diagram for a lt166 john deere mower
From the JD site, you can get the drive and deck belt diagrams here:
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
***Don't forget to VOTE for the guys who take an interest in helping!
Testimonial: "i think this will help my husband immensely"
SOURCE: I need a belt routing diagram for a John Deere
If you go to this page http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO , scroll down the left side to the heading for your deck.
