Cell Phones Logo
Patricia Menguito Posted on Oct 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Finger swipe didn't work and the password won't open my phone what can I do now?
David Jewell
Level 3:
  • Master 454 Answers
  • Posted on Oct 05, 2015
David Jewell
Master
Level 3:
Answers
454
Questions
Helped
141645
Points
1316
You can do a hard reset, but you will lose all of the files on your phone. Make sure your battery is fully charged or plug in your charger. Press and hold the volume down button and the power button until the borrower screen comes up. Scroll down to the factory reset button and press the power button to select. Tue phone will wipe itself and reset itself. Be patient, it will take some time. Do not turn it off before it is finished, or you will brick your phone.
New phone and don't understand PAMPHLET.
Most phones are finger swipe controlled. You place finger on the screen and drag it to get to the next screen. To dial a number swipe across screen and find app called phone
press finger on icon to open application.
If you tell us what you don't understand we might be able to explain it more accurately.
Jan 22, 2016 • Cell Phones
3helpful
Talk back mode is on and I cant get into my phone. Have taken battery out several times and still cant get into my phone. It just keeps making sounds when I try to put in my password.
Samsung Galaxy S3: Talkback Mode On: Can't enter password:
If you have a password on your device then you will need to double tap on the screen to gain access to the lock pattern or code that you have on your device. While in Talkback mode you will need to double tap any selection in order to fully make that selection.
You need to double tap on the screen pause for a second then swipe your screen In order to gain access to your device. You cannot double tap quickly then go to the process of swiping to open our device
Reference Link:
Disable Talk Back Mode in Samsung Galaxy S3
Unlock Phone in Password Mode:
If you have chosen the Password Unlock mode on your phone and are unable to enter the password due to the Talkback mode, do as follows. First of all long press the password field and then double tap it. Now you will see the keyboard. Long press the alphabets/numbers of your set password and when you have typed it, long press/double tap the "Done" button on the keyboard. You can now follow the two finger swipe and double tap as described above to deactivate the Talkback mode.
Reference Link:
How to Disable Talkback on Android Devices
2answers
I have a new galaxy S5 and i set it up with fingerprint to unlock but it keeps going reverting to password to unlock, how do i get it to stay on fingerprint?
Here is another way to unlock pattern lock for Samsung Galaxy phones, also works with password, fingerprint and PIN. Moreover, no data loss
http://www.youtube.com/watch?v=lw4ueft-t_I
Oct 06, 2014 • Cell Phones
1helpful
Swipe wont open phone
It seems that the digitizer is not working properly, if you bought new i suggest you return it.
1helpful
How to format E72 that won't charge in either nokia charger nor USB cable. But once it open it only vibrate then NOKIA sign appears and yet it won't open. please HELP ! thank you !
For Hard Reset:
This also restore your Nokia when it frezzes at the nokia screen logo only and didn't go any further.
hard reset is an options but will result to loosing all settings, contacts, data etc...
Turn your phone off and simultaneously press these four buttons circled in red.
* * (asterisk key)
* 3 (numeric 3 key)
* CALL / GREEN key
* On button
This is another method below found out by trial and error when the * + 3 + Call didnt work.
Switch your phone off.
Then, lay it down on a flat surface
With 3 finger of one hand, keep pressed shift, space bar and back space all at the same time
With one finger of the other hand, press the power on button
Do not release neither the 3 keys nor the power key till you see the nokia shakehands animation.
2helpful
2answers
How to switch off finger swipe
Go to control panel, and find the user account settings. Here you can tell the computer not to ask for password or finger swipe when it starts up.
HAVEA TOSHIBA LAPTOP WITH A FINGERPRINT IDENTIFIER TO OPEN WINDOWS, WANT TO CHANGE THE FINGERPRINT TO MY DAUGHTERS. HOW DO WE ACCESS THIS?
dentifying the fingerprint readerA fingerprint reader provides extra security for the PC. The VeriSoft Access Manager by Bioscrypt uses the fingerprint reader to identify the user, and controls access to Windows or other secure systems. Instead of typing a User ID and password, you can move your finger across a sensor to logon or start commonly used applications. Verisoft Access Manager can manage all of your different secure accounts and the required user names and passwords by recognizing your fingerprint.On HP notebook PCs, the fingerprint reader is a small metallic sensor located near the keyboard or display. By swiping your finger perpendicular to the metallic sensor you can logon to the PC, a network, or open a program. c00897920.gifBefore you can use the fingerprint reader, you must set up the fingerprint reader by registering your fingerprint with the Access Manager. Set up the fingerprint reader To set up the fingerprint reader to recognize a user, the user must have a logon account on the PC and the account must have a password. Multiple users can be registered for the fingerprint reader if each has their own user account.
  1. In Windows, double-click the VeriSoft Access Manager icon c00897921.gif in the notification area of the taskbar to open the My Identity window. Alternately, click Start > All programs > Verisoft > My Identity .
  2. Click Log On to open the VeriSoft Logon Wizard. Click Next to begin.
  3. Enter the User's Windows password in the Password field on the Introduce Yourself page, and click Next . If you have successfully logged on to Windows, click Finish to close the wizard.
  4. Click Register Fingerprints on the My Identity window, to open the VeriSoft Logon Wizard. Click Next to begin. c00897922.gif
  5. Select a finger shown on the hand graphic, and then slowly swipe your finger across the sensor. One of the squares below the hand graphic will change color when the scan is accepted. A message displays if the scan is not accepted.
  6. Swipe the same finger across the sensor again until all four squares change color, then clickNext to register the finger print. If you need to start over during the fingerprint registration process, right-click the highlighted finger on the screen and then click Start Over .
  7. If prompted to register a second fingerprint, click a different finger on the hand graphic, and then repeat steps 5 and 6.
  8. After using the Registration Wizard to registered at least 2 fingers, click Finish .
  9. To set up the fingerprint reader for a different Windows user, log on to Windows as that user and then repeat steps 1 through 8.
After registering your fingerprint you can log off and then use your registered fingers to log on to Windows. Using Fingerprint reader before registeringIf you swipe your finger across the fingerprint reader before it is set up, the Access Manager opens a logon wizard window and prompts you for informa
3helpful
Don't have authorized finger swipe or password.
Hi ginamarieanc,
There is always a password associated with the "finger swipe"
If he somehow managed to setup without a password you would be able to hit the enter key with the password bar blank and get in.
If you get an incorrect password error that means there is a password.
If you could get him to let you in once you could change the password. The only other way is to remove the cmos battery and reset the bios, you would need to disassemble the laptop to do that.
If I was a CSI I would be able to tell you how to lift his print off of a glass of water and make a mold of it(just kidding, I don't think that works)
Sorry I couldn't be of more help but let me know if I can help with removal of the cmos battery.
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
1helpful
I have dv9000 notebook computer. how to config there finger print password
1. In Windows, double-click the VeriSoft Access Manager icon in the notification area of the taskbar.
2. On the “My Identity” page, click Log On, located in the upper-left corner of the page.
The VeriSoft Access Manager Logon Wizard opens.
3. On the “Introduce Yourself” page, enter the user's Windows password, if one has been established,
and then click Next.
4. On the “Services and Applications” page, click I want to, and then click Register Fingerprints.
NOTE: By default, VeriSoft Access Manager requires registration of at least 2 different
fingers.
5. When the VeriSoft Access Manager Registration Wizard opens, click Next, and then slowly swipe
NOTE: The right index finger is the default finger for enrolling the first fingerprint. You can
change the default by clicking the finger you want to register first, on either the left hand or
the right hand. When you click a finger, it will be outlined to show it has been selected.
6. Continue swiping the same finger over the fingerprint sensor until the finger on the screen turns
green.
NOTE: The progress indicator advances after each finger swipe. Multiple swipes are
necessary to register a fingerprint.
NOTE: If you need to start over during the fingerprint registration process, right-click the
highlighted finger on the screen and then click Start Over.
7. Click a different finger on the screen to register, and then repeat steps 5 and 6.
NOTE: If you click Finish before registering at least 2 fingers, an error message is
displayed. Click OK to continue.
8. After you have registered at least 2 fingers, click Finish.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
