I had this happen on my Dell Studio with slot-type drive. Pressing the Eject key next to the function keys didn't work and the drive did not show up in My Computer. Eventually it ejected itself when I switched off, switched back on and repeatedly clicked on the above mentioned eject key whilst the computer was booting.
if you keep the mains charger plugged in all the time then this can cause the battery to heat up. if you use the laptop in the same position all the time then try removing the battery for use or when the battery is fully charged then remove the charger, this will also preserve the lifespan and battery operation.hope this is of help to you,
press on/off (power) switch on ur mobile now remove your battery and reinstall the battery without releasing the on/off switch. repeat this 3-4 time without releasing on/off switch.
try moving the monitors. it could be feedback signal. also try different leads or without switch. you will then be able to narrow down the problem to one component.
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
The need to reboot your computer to get your monitor working places the blame totally in the computer. You have a virus, or the computer is overheating and shutting down for thermal reasons.
-CharlyV
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
