EPIC 400 tread mill starts but slows down &blows breaker moter run fine with no load belt backed off re set speed sensor changed power cord pluged .in to circit board ran fine for 2 hrs then stoped
follow this steps and fix it. See the diagram attached. God bless you ERR
1 - Motor Movement
ERR1
indicates a speed issue. In this case, the motor speed as reported from the
optic sensor differs
from the
speed setting.
Analysis:
Optic sensor signal issue -- Either the optic sensor signal is not right, or it
is read incorrectly, or
the signal is not reaching the display. Of course you must lube the deck belt. see the video attached.
1) test your circuit breaker home,reset 2)test the outlet for 115 vac 3)test the power cord if some wires is loose or cutting 4)reset your circuit breaker insider from your equipment 5)Eliminate any extension cord from your treadmill. 6)Be shure if the receptacle have ground cable with your divided TRSS.
Dear Sir: Thank you by your problem, I will help you inmediately.
Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps. Important: The treadmill is not compatible with GFCI-equipped outlets.
2)After the power cord has been plugged in, make sure that the key is fully inserted into the console.
3)Check the circuit breaker located on the treadmill near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch back in.
4)Check the on/off switch located on the treadmill near the power cord. The switch must be in the on position.
I hope you resolve this. Otherwise, try to reach me. Inmediately.
By E7 it means Speed sensor feedback missing. You have to check the speed sensor mounted near the motor pully. Remove the speed sensor and clean it well Then refix it then check the tread mill by powering ON. If then also the problem remains the same , You have to replace the speed sensor.
ok
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
