Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
Rca remote control code list
I need the code for a rca universal remote control # rcu600wms to control a Toshiba dvd player mod# sd-k730.
Thanks Mark
  • 6 more comments
  • Anonymous Dec 22, 2007
    need codes to control a sansung tv
  • monet15 Aug 14, 2008
    need tha code to a universal rca remote control for a celera television
  • Anonymous Aug 18, 2008
    What code do I use to control a panasonic tv with my rca universal remote rcr4358 r55l8 5719p
    thanks
    marge
  • Anonymous Sep 08, 2008
    rca remote cannot find code for acer tv lcd
  • rjs5111 Oct 05, 2008
    I need the codes to set my television
  • grewalranjod Oct 26, 2008
    i have remote rcr311tbm2 iwant codes for tv sunsui
  • PAT1915 Nov 19, 2009
    I HAVE RCA TV AND A JENSEN UNIVERSAL REMOTE I NEED T O GET CODES TO PROGRAM MY TV TO GO ON AND OFF AND CHANGE CHANNELS
  • andy stewart Sep 03, 2013
    I need the code for a rca universal remote control # rcu404n to control my tv
OK GANG: HERE GOES, I PURCHASED A RCA REMOTE (RCR312W), 3 CHOICE FUNCTION.
SAT-CBL...TV...VCR-DVD.
I HAVE 2 DIFFERENT TV'S, DAEWOO TV AND A PANASONIC TV/VCR. THE REMOTE HAS
WORKED ON BOTH SETS. I DROPPED THE REMOTE WHEN IT HIT THE FLOOR THE BACK
FLAP HOLDING THE BATTERYS KICKED OFF AND ONE BATTERY FELL OUT. I WENT NUTS
FOR 2 DAYS TRYING TO GET THE CODE FOR THE DAEWOO. TODAY 11/14/2008 A FRIEND
GAVE ME A PANASONIC TV/VCR 20". AGAIN I TRIED TO FIND THE CODE, DIDN'T WORK OUT EASILY, AGAIN DRIVING ME LOONY TUNES IF YAA KNOW WHAT I MEAN.
HERE IS THE SKINNY: SOLUTION TO YOUR PROBLEM !!!! IT DOES WORK.
1, TURN ON THE COMPONENT YOU WANT TO PROGRAM.
2, PRESS AND RELEASE THE COMPONENT BUTTON ON YOUR REMOT THAT CORRESPONDS TO THE COMPONENT YOU WANT THE REMOTE TO OPERATE.
TV, VCR, ETC... THE ILLUMINATED ON-OFF BUTTON WILL TURN ON AND STAY ON.
3, NOW PRESS BOTH BUTTONS ON-OFF AND TV, OR: ON-OFF AND CBL. WHAT EVER.
THE ON-OFF BUTTON ON TOP OF THE REMOTE WILL TURN OFF, KEEP PRESSING
AND IT WILL COME BACK ON AND STAY ON. RELEASE THE BUTTONS,BOTH.
ON-OFF WILL STAY ON NOW.
4, KEEP POINTING THE REMOTE AT THE COMPONENT, THE REMOTE AND THE TV
NEED TO TALK TO EACH OTHER,(MAKES SENSE.)
5, GO TO THE BOTTON OF THE REMOTE AND PRESS THE "PLAY" BUTTON,
RELEASE. "" KEEP PUSHING THE PLAY BUTTON EVERY 5 SECONDS,
UNTIL THE TV TURNS OFF"". OR THE VCR, OR THE CBL, WHATEVER YOU ARE
PROGRAMING.
6, NOW: PRESS AND RELEASE THE "REVERSE" BUTTON, THIS IS AFTER THE TV
HAS TURNED OFF. TV SHOULD TURN BACK ON WHEN THE "REVERSE" BUTTON
IS PUSHED.
7, IF THIS WORKS THE LAST STEP IS TO HIT THE "STOP" BUTTON,
THIS WILL SAVE THE SETTING. REMOTE SHOULD BE PROGRAMED AND TURN
THE TV ON AND OFF. YOU DON'T NEED THE SILLY CODE NUMBER, THE REMOTE
DOES THE ACTIVE PROGRAMMING AUTOMATIC.
HOPE THIS HELPS YAA ALL... "PEACE".........OKIE
Posted on Nov 15, 2008
    Novelist:
  • 111 Answers
Unfortunately i do not have a code for that specific model, you can however try the automatic code search method.
1) turn on the dvd player
2) press and hold the code search button, when the indicator light is lit, release the code search button
3) press and release the component button you wish to use (dvd), the indicator light should blink once and remain lit
4) aim the remote at the dvd player and push the on/off/power button, there is a 3 second pause between codes, so keep the remote aimed at the dvd player
5) as soon as the dvd player turns off via remote, press and release the enter button
now to record the code for future reference..
1) press and hold the code search button, when the indicator light is lit, release the code search button
2) press and release the component button you wish to use (dvd), the indicator light should blink once and remain lit
3) press and release the code search button, the indicator light should turn off
4) starting with 0, press and release each button in numerical order (0-9) until the light blinks, write down the number that caused the light to blink
repeat step 4 two more times until you have the 3 digit code. in the future you can use the direct programming mode to reprogram the remote if need be.
hope this helps,
trin
Posted on Nov 16, 2007
  • Trinity Sabre
    Trinity Sabre Nov 16, 2007
    since my last answer didn't cut it (sorry about that, figured the remote code search had a better chance of auto identifying it than i would), here is a complete list of supported toshiba codes for dvd players, these are the only codes supported by your remote, if this fails, you may want to look into buying a new remote.
    Code For Model RCU600WMS
    Code
    162
    for
    Toshiba
    DVD
    Code
    167
    for
    Toshiba
    DVD
    Code
    362
    for
    Toshiba
    DVD
    Code
    363
    for
    Toshiba
    DVD
    Code
    405
    for
    Toshiba
    DVD
    Code
    406
    for
    Toshiba
    DVD
    Code
    407
    for
    Toshiba
    DVD
    Code
    603
    for
    Toshiba
    DVD
I have the RCR3273/3373Remote,cant find the code for my<CineVision DVD+VCR.How can I program it?Please replay
Posted on Oct 19, 2008
I have a rca universal remote that i need codes for my magnavox tv dvd vcr combo can some one help me please thank you.
Posted on Sep 09, 2009
    New Friend:
I need a remote control for my pyramind 530a amp
Posted on Dec 06, 2013
I have an RCA dvd player that I have lost the remote too! I have purchased a universal AVEX R6 remote control. I have used all the methods in the user manual to have this remote learn the code to this unit and the only thing it has done is turned on the mute. The model # to the dvd player is DRC 279A. I hope you can help!
Posted on Mar 17, 2010
The brand of my dvd player is LEITY and I have been looking for it remote,I am not getting it.Can you PLEASE send me the code so that I can use universal remote to operate it.
Thank you
Posted on May 30, 2009
Hey , how you doing i am fine.. i want tell you something i have problme and how rca remote code for apex and please you help me for direct and so i need if you send me my email mryt_wllms@yahoo.com please send me code thank you from tia
Posted on Oct 14, 2008
  • Anonymous Oct 14, 2008
    hey you will help me code for rca remote for apex
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: rca remote control code list
i need the codes for a rcu404 universal remote for sony dvd player
Posted on Aug 23, 2009
Remote codes for samsung blu-ray
Universal Remote Control Codes List - TV SAT DVR ...
removeandreplace.com/2013/11/10/universal-remote-control-codes-list/
Nov 10, 2013 - We recently bought a universal remote control for an extra bedroom and ... To control a Samsung Blu-Ray DVD player with an RCA universal ...
3 Digit Universal Remote Codes For DVD ' Codes For ...
codesforuniversalremotes.com/3-digit-universal-remote-control-codes-d...
... of the 3 digit device codes for DVD and Blu-Ray 3 Digit Universal Remote Control Code List ... Need 3 digit remote code for samsung blu ray player BD-J5100.
Support - Blu-ray Players BD-H6500 ' Samsung Home Audio
www.samsung.com > ... > Blu-ray Players
Samsung Electronics
Jan 16, 2016 | Samsung Televison & Video
Remote menu button not working
Sometimes you can enter a code that will work nearly all the buttons, but is not the correct code for your DVD player. You should try other codes. But sometimes a universal remote will NOT work every function.
Dec 22, 2012 | Toshiba SD-V392 DVD Player/VCR
I cannot program program this universal remote to use it with a Sharp TV.
http://www.retrevo.com/support/RCA-RCU600WMS-Universal-Remotes-manual/id/402dj594/t/2/ provides a downloadable manual for your remote.
The TV codes for a Sharp TV are 173, 095, 171, 004, 006, 012, 029, 111, 112, 113, 12 in case a "Code Search" from your remote doesn't extract and/or store the codes.
Hope this helps.
Feb 22, 2011 | RCA RCU600WMS Remote Control
I have a universal remote and need the code for a magnavox dvd player to program the dvd player thank you
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Please
Provide model of your remote
device to be programmed (VCR,TV)
Make name(toshiba,sony)
Thanx
Jul 28, 2010 | RCA RCU404 Remote Control
Is an RCA remote control RCU600WMS compatible with a Norcent TV? If so,what is the code?
There is no published code for the Norcent TV on the RCU600WMS. I would follpow the instructiions on the left margin of
http://www.rcaaccessories.com/RcaaccessoriesController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_UNIVERSAL_REMOTES
to find the code.
Please rate this solution. Thanks.
Jun 06, 2010 | RCA 4-in-1 Universal Remote Control
I have the RCA RT2370 home theater, need the codes for the remote
I have 015, 055, 049, 051, 065, or 116 listed for a Toshiba VCR. Maybe one of those codes will work.
Jan 15, 2018 | RCA Audio Players & Recorders
Jan 11, 2009 | RCA RCU404 Remote Control
Code for a Panasonic TV/VCR
Hello, Urpurdy -
Am I safe to assume you have the user manual (in printed / paper format) for the RCA RCU600WMS remote control? If you do not, you can find it and download and save the PDF document here: https://voxxintl.zendesk.com/hc/en-us/articles/225306867-Information-User-Manual-and-Code-List-for-the-RCA-RCU600WMS-Universal-Remote-Control . You can then print it from the saved document. Tip: I suggest you set up a file folder in your computer Documents folder, titled: RCA TV Remote (or something like it, so you can find it whenever you may need it.) Also, I print the user manual out and keep it near the TV for future reference.
The user manual includes the programming instructions and code lists starting on page 6 (PDF page 4).
Best wishes.
Dec 17, 2017 | RCA RCU600WMS Remote Control
I NEED REMOTE CODES FOR THIS DVD RCA DRC200N
I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
Oct 17, 2007 | RCA DRC200N
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
37,713 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
