SOURCE: Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is [email protected]
SOURCE: Blue to Black screen on Sony KP-57WV600
Rowdyroddy,
Thanks you so much for this info.
I had the same problem with my Sony KW-57wv600. Blue screen turns black after a few seconds, and then standby light flashes seven times.
I called a local TV technician, and described problem. I was told it would not be cost effective to fix. After reviewing the "simple" instructions given on www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html I figured I had nothing to lose.
10 minutes to remove front panel, a "very slight" turn of a screw, and TV worked again perfectly. I could not believe it!
Thank you so much for your help!
SHAME ON SONY FOR NOT POSTING THIS FIX ON THEIR WEBSITE! SHAME ON THE TECHNICIAN AT SONY WHICH INSISTED A SERVICE TECHNICIAN WAS REQUIRED.
I have always been a fan of Sony, swearing by Sony products exclusively. After this experience, I am now forced to consider some other options when purchasing electronics in the future.
SOURCE: Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
SOURCE: no picture or sounds red light blinks 10 times
The parts you need are two diodes, D6301,
D6309, and D6116, Sony part numbers 6-500-567-21 (D6301 and 09) and
8-719-081-97 (D6116), they are located on the G board, and that's
located on the left side of the set, as seen from the back.
D6116 is connected to pin 9 of transformer T6101, and D6301 and 09 are in series off of pin 7 of that transformer.
