I have a 2008 Yamaha vx110 deluxe waverunner. It idle's really high at about 6k rpm at 20-25 mph. It normally should idle at 2-3k rpm at 1/2-1 mph. Whenever I tap the throttle it idles normal for about 3-5 seconds then goes back up to high idle. I checked the throttle cable and it is working correctly. The only thing I can think it could be is the throttle sensor in front the ski or the sensor on the motor itself. If anyone has had this problem please help. My waverunner isn't under warranty so I have to figure this one out on my own. Any help will be greatly appreciated
It can be issue
with IAC( idle air control valve) causing the problem.
There
are many other possibilities causing these idle issues. Engine idles rough.
There
are few help links with solutions to troubleshoot such idle issues.
I
suggest you refer the link below and follow
its troubleshooting details:------
Click
the link below:-----
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to
3500 rpms
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High
Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These
details will help.
Thanks.
