All connections good no burnt wiring. 240 volt...power is good to unit. timer works... but no heat.
SOURCE: heater only gets mild warm Tylo sport 4 heater
more than likley installation problem not enough voltage top operate heating element
SOURCE: My tylo supersport 8 sauna
Remove the unit bottom panel (2 small screws) and look at the quick disconnect terminals on the heater rods ( 6 heating rods - 3 on each side of the unit). If you have any corrosion on these terminals, the wires will overheat and fail, preventing the heating rods from working. If the wires did overheat, you should see melted wire insulation. Replace bad wire and quick disconnect terminals with new. Should cost less than $20.
