Well lets see your saying oil flow sensor so it must be a four stroke engine four stroke engines are not reed enducted so the reeds would be out they only have one sensor for the oil per bank it might also be a water flow unless u have a gauge is the boat running bad or getting hot is the buzzer still going off? a couple things u neeeed to check make sure u have good water preasure first then find the oil flow sensor and unplug it buzzer should go off make sure the engine is not gettin hot you should be able to touch the water jackets (heads) with your hands and not be to hot if u have good water preasure do nont hook up to hose fitting on thee engine go old scholl and use water muffs on the lower unit that will give u a acurate reading on flow becuase the impellar has to pull it up if that doesnt fix it let me know thank you thomas
The links below hve a detailed features and manuallinks for you.
have a look:
http://www.suzukimarine.com/sr_09/df175-150/
http://www.autosmanual.com/category/suzuki
Please do rate the solution. Thank you for using
fixya.keep updated. thanks
Hi mongo,
looking at a possible reed damage, the effect do not reflect the same manner but the error you have is all pointing to the oil / air / gas going to the block before combustion. you may have this checked by a mechanic to completely decipher the issue for repair.
hope this gives you an idea, as the service manual has the meaning the the fix for the error.
regards,
voodoo
Get the
coolant pressure tested, its definitely leaking coolant. You will need to get
the coolant running line.
Pressure
test will help you to know from where exactly coolant/refrigerant is getting
leaked.
For complete
step by step troubleshooting i suggest you to go through the help links
mentioned below :----
Click the
link below :-----
Coolant enters in transmission on Toyota Land cruiser?
http://schematicsdiagram.blogspot.com/2012/01/coolant-enters-in-transmission-on.html
1991 Toyota
Camry: Order Coolant Bypass Tube?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-camry-order-coolant-bypass.html
2002 Toyota
Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
1994 Toyota
Camry: Coolant Leak?
http://technoanswers.blogspot.in/2012/04/1994-toyota-camry-coolant-leak.html
2006 Cadillac DTS: COOLANT LEAK AT DRIVER SIDE NEAR
FIREWALL?
http://schematicsdiagram.blogspot.in/2012/04/2006-cadillac-dts-coolant-leak-at.html
MAF, IAT, MAP and Coolant Level Sensor problem all together
on Mazda MPV?
http://schematicsdiagram.blogspot.com/2011/12/maf-iat-map-and-coolant-level-sensor.html
GMC Engine Coolant Temperature (ECT) Sensor Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-engine-coolant-temperature-ect.html
Loosing Coolant?
http://whoisbyme.blogspot.in/2012/06/loosing-coolant.html
Coolant temperature sensor dies again and again?
http://schematicsdiagram.blogspot.com/2012/01/coolant-temperature-sensor-dies-again.html
2000 Daewoo Lanos: Where to Add Coolant?
http://repairhelpcenter.blogspot.in/2012/06/2000-daewoo-lanos-where-to-add-coolant.html
Blue Water Warning Light on Dash?
http://whatisbyme.blogspot.in/2012/07/blue-water-warning-light-on-dash.html
Replacing
Oldsmobile Engine coolant sensor?
How
to test Engine coolant temperature sensor?
Replace
Coolant Sensor Module on Oldsmobile?
These details will help.
Thanks.
Get the
Pressure
leaked.
For complete
Click the
link below :-----
1991 Toyota
2002 Toyota
1994 Toyota
FIREWALL?
on Mazda MPV?
Loosing Coolant?
Replacing
How
Replace
Thanks.
i am an auto mech (for way too long) is the alarm i'm talking about an oil flow sensor,is there separate ones for each bank like the coolant level ones?
if there is reed damage,what kind of damage could this cause,cause the motor still ran fine...what caused this problem is i raised the motor to high so she wouldnt get up on plane..as the boat almost reached plane the prop would cavitate causing the eng to rev,almost like prop slippage,but it's not that..
i have great water coming out of the engine...
it still runs fine...not overheating
i'll have to find the sensor and try inplugging it..
and i dont know if it's an oil flow light or not....it has four total 'flow' lights...two larger ones on top and two smaller ones on the bottom. the r/s bottom one is the one flickering with a queiter alarm than the larger one...and in the middle of the guage is two led bars which light up green....
.if i could find a picture of it or a manual somewhere,it would point me in the right direction
