Question about Vehicle Parts & Accessories
How do you install directed dei 652t - Vehicle Parts & Accessories
    Top Expert:
  • Vehicle Part... Master
  • 10,079 Answers
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
Posted on Jan 31, 2019
6ya staff
SOURCE:
On a DEI 514N siren, what do the 2 small wires connect to?
They are for configuring the siren for louder soft chirp or one tone siren.
Dec 28, 2013 | Dei Directed Viper Python 514n Soft Chirp...
Finding a light kit for a casablanca 652T fan
That's an old model so I don't know without seeing a pic for sure. If it has three screws on the bottom plate,you have to use an older Casa. light kit or almost any Bowl light should work. fanman9952@aol.com
Mar 27, 2013 | Dryers
I have a horn that sounds when my hay baler chamber is full. I am looking for a timer relay that will allow the horn to sound for 3 to 5 seconds and then disconect the circuit so it won't drive me...
DEI 528T appears to be 12Volt 'wait to start' or ON-delay timer.
528 receives electrical signal, and then delays the start-circuit by up to 60 seconds.
For example home alarm system. Door is opened and alarm sounds. Install DEI 528 and set for 60 seconds: Door is opened and alarm will not sound for 60 seconds.
You need 12-volt off-delay timer.
Off-delay timer receives electrical impulse, and then begins a countdown.
After countdown expires, then circuit turns off.
ELK-960 appears to have off-delay feature for 12V DC
http://www.homesecuritystore.com/p-423-elk-960-delay-timer-module.aspx
Use wiring diagram #7 for alarm cut-off:
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ELK-960_Install.pdf
Aug 25, 2011 | Directed Electronics Dei 528t Pulse Timer...
Remove security off a 1990 camaro because changed the ignition
One way is to change out the chip from the cars computer. Another way is use a General Motors GM VATS Override Bypass Kit, I'v learned that there is a pre-packaged set of resistors for the 15 GM resistor values I found a place called Sonic Electronix. Sonic here it is: http://www.sonicelectronix.com/item_...+DEI+652T.html
There is also a bit of misinformation on the internet Some tips I've learned when searching out this.
Example: Myth: The standard ignition cylinder lock will not fit or work in place of the vats ignition cylinder lock. Wrong! The standard 1990 camaro cylinder lock fits slightly deeper inside the column, so this takes away your ability to push in the key and turn it backwards for the accessory position. Other than that, it works fine for turning on the ignition.
I hope this helps some.
May 13, 2010 | 1990 Chevrolet Camaro
Dei automate remote starter 552 for manual gear installation
It can be installed, but is not recommended. If the car was left in gear and the auto start activated the car will lurch forward. A friend of mine, who is an installer, had his WRX jump a curb in a parking lot in land in a ditch. BTW, he "never left his car in gear". It only takes once.
Nov 08, 2009 | Directed Dei Valet 561r Remote...
I want to have my valet model 561r removed it is malfunctioning my car is reviving up and dying on turns it also will no longer start the car
Not possible. The DEI's brand Valet has nothing at all, anywhere close to or connecting to the accelerator or acceleration of ANY VEH.
Oct 11, 2009 | Directed Dei Valet 561r Remote...
How to install a DEI/BOA 555L GM Passlock 1 & 2 Immobilizer Bypass
goto www.bypasskit.com and click search by product, follow the instructions to download the instal manual, good luck
Sep 06, 2009 | DEI GM Immobilizer Bypass
I am trying to find an installation manual for a python 1400xp online.
Have you tried DEI's web site and go to support and scroll down to where you see installation manuals for that alarm and either save it or print it ( have lots of paper though because the ****** is 56 pages)
Aug 10, 2009 | DEI Python 1400XP Remote Start/Keyless...
Vehicle Parts & Accessories Logo
102 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Vitally Alcher
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
