E33 - Inconsistency between level on electronic
pressure switch and level on anti-boiling pressure
switch 1(fault persists for at least 60 sec.).
When is this fault occurs than will be performed emergency drain procedure, cycle stops with door unlocked.
Dado
SOURCE: Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
SOURCE: washing machine zanussi jet wash
unplug machine turn water off then take water pipe off machine,take machine outside and lay on its back,there is two moters up in the top right off machine looking in the bottom of machine, undo the three pipes and two/three srews take both pumps out undo three screws on the top pump split it and unblock then pup it all back.remember to right down wot you have done to pup it back right,it took me approx half hour to fix mine
SOURCE: error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
SOURCE: Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
SOURCE: anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
