Sewing Machines Logo
A
Anonymous Posted on Sep 24, 2015
What is the bulb for the 258 singer sewing machine
Level 3:
  • Singer Master 6,688 Answers
  • Posted on Sep 24, 2015
Cindy  Wells
Singer Master
Level 3:
Answers
6688
Questions
0
Helped
3530717
Points
21745
Singer has the parts list for the 258 on their support site: http://www.singerco.com/support/replacement-parts-chart . The direct link is http://parts.singerco.com/CPpartCharts/2_2999/258.pdf . The lamp is shown on page 6. The part number is 603938-001 or 603938-002 (Light L 11) depending on if the machine's motor is UL or Standard. Amazon has a couple of vendors that list the 603938 bulb. One of the vendors is http://www.amazon.com/Singer-Long-Light-Watt-120-Volt-Push-In/dp/B0001DUOSY .
I hope this helps.
4 Related Answers
sewtexas
  • 136 Answers
  • Posted on Mar 19, 2010
SOURCE: Singer 258
There is no speed adjust, but 1st you must know the source of the slow down. Remove the belt from the motor pulley and run it, if it goes fast try turning the hand wheel if it is stiff the machine needs clean and oil. If it turns freely you motor may be dirty or just slow. If dirty, sometimes you can without the blet attached run it at full speed for 10 to 15 minutes. It should get faster as you run it. If not motor is weak or slow needs replace. Just replacement motor as genuine probably no longer available.
Anonymous
  • 1116 Answers
  • Posted on May 07, 2010
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here - http://www.singerco.com/accessories/manuals.html
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Oct 15, 2012
SOURCE: How do I change the light bulb in my Singer 2210 sewing machine?
here's a link for a free manual,, look on page 45 & see if that page
show how to change the light bulb
http://www.singerco.com/uploads/download/642_2210.pdf
Testimonial: "Thanks so much for responding! New bulb in and working! Thanks"
richie46
  • 12962 Answers
  • Posted on Jul 13, 2015
SOURCE: Will the bed plate from any other singer machine fit the 258 from 1974? I can't seem to find the 258 bed plate anywhere.
Did you contact support at Singer? Did you google it? Did you check with a sewing machine repair outlet?
I have a Singer sewing machine 9618 and the light has finally burned out after a gazillion years. How do you get the bulb out?
To replace the light bulb on your Singer sewing machine model 9618, please follow these steps:
  1. Turn off the sewing machine and unplug it from the power source.
  2. Locate the light bulb cover on the left side of the sewing machine, just above the needle.
  3. Use a small flat-head screwdriver to gently pry the cover off.
  4. Remove the old bulb by gently pulling it out of the socket.
  5. Insert the new bulb into the socket, making sure it is securely in place.
  6. Replace the cover by aligning it with the slot and gently pressing it back into place.
Note: Make sure to use a light bulb that is compatible with your sewing machine's voltage and wattage specifications. You can find this information in your sewing machine's manual or on the light bulb itself.
How do you change bulb on singer curvy 8763? Nothing in manual, nothing online. Can it be replaced? Seems to be soldered in or something and no replacement listed either.
The Singer Curvy 8763 bulbs are LED bulbs so they should last for 100,000 hours (or probably the life of the sewing machine). Thus the bulbs aren't meant to be user replaceable. Unfortunately, even though the bulbs should last for years, Singer only provides a one year warranty on them. Thus if your machine doesn't have working lights and isn't still in that first year, you'll have to pay for the repair.
I hope this helps and wish I had better news for you if there is a problem with the lighting of your sewing machine.
How do you change light bulb on Singer 7444 portable sewing machine?
Instructions regarding changing the light bulb are in your user's manual. If you don't have it, you can download a .pdf copy free from the Singer site, and here's the link. Instruction Manuals
2answers
How to oil a singer fashion mate 258
Try searspartsdirect.com
They have all brands.
I own a Singer 258, the needle does not pick up the bobbin thread
is the needle the right one for the machine?
is the needle & thread correct for the fabric?
it's possible that the machine is out of time & would have to be retimed by a sewing machine shop
I have a Singer Advance 7422 Sewing machine. The light bulb went out. How do I change it and where can I find a replacement bulb?
My light went out of my Singer advance 7422. Does anyone know how to change it or where to buy the bulb? Thank you for your help.
Jun 05, 2011 • Singer 7422
1helpful
1helpful
Singer 258
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
