Canon Cannon Unitroll 10 Manual Downrigger Logo
J
Johnny Arnold Posted on Sep 24, 2015
How do remove the spool from the downrigger - Canon Cannon Unitroll 10 Manual Downrigger
Cable jumps off of roller at end of boom
I've had the same problem with my electric Walker down-riggers, the line guides didnt work well because of the crimp for the cannon ball return pully snags on the guide, the best I came up with is a cannonball snubber similar to ones used with Dipsey-Divers, made heavier for cannonballs, hope this helps
2answers
My downrigger goes down slow and comes up slow
you need to make sure that you are using a heavy weight. I use 20 pounds.
1helpful
Looking for parts & service: mag 10A cannon downrigger
Your best bet for price is looking on ebay, there are lots of links off of an inquire.
1helpful
2answers
IHAVE A CANNON MAG 5 AND THE CABLE RUST UP ON ME CHANGED CABLE AND IT DID IT AGAIN IN ONLY 4 HRS
Corrosion is caused by small amounts of electrical current flow following the path of least resistance and jumping off one piece of metal to another one thus taking a small piece of metal with it when it goes. You have to either eliminate the current flow or slow it down or make it go somewhere else. The positive ion control in these downriggers can probably add to the problem. Also if you're fishing in salt water, it is a natural electrolyte and if two differnt kinds of metal are in saltwater, they creat a natural battery and produce enough electrical current to corrode the metal. I would suggest maybe using a sacrificial anode. It's a piece of metal with lower resistance to electrical current flow than the metal you're trying to use, thus is corrodes the anode before corroding the metal you're protecting. Anodes are made of metals like aluminum, zinc and magnesium. If you had a small piece of one of those metals and wrapped it around the downrigger spool before you wound the cable onto it, it would rust it out before rusting your cable. You can also try turning down your Ion Control. I've seen my cable rusting a little bit but it doesn't seem to be that bad or rust so fast. I'm wondering if you're using a different kind of metal for your cannonball?
Cannon downrigger
score along the seam with a razor knife just below the cover where the screws are you need to reach an 1/16th inch deep insert a screw driver into the rubber gromet where the power cord goes in and pry open the cover be very carefull not to use any of the insides as a lever and use finess not brute force
6helpful
2answers
Used (older) Cannon Digitroll II Manual or advice
I have the quick start manual for digi-trol II. I will try to scan it and post later today.
Kevin
1helpful
Cannon Digitrol 1V bottom tracking not working
Hello!
Here is the user manual for your downrigger:
DT IV Downrigger
The programming starts on page 12.
Best of luck!
Mike
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
