SOURCE: When taking photos at a basketball game and with
Does the background look blurry? I suspect what you are getting is called motion blur. You need a faster shutter speed, which is either possible by having more light in the room or a faster lens.
If you want to try to get the best shot (with your existing equipment) possible of sports under low light conditions you may have to set some controls manually.
Use the Av mode, and set the Av number to the smallest one possible.
Adjust the ISO by pushing the ISO button on the back and setting it to the highest value (note: this results in a "noisy" picture, you will sacrifice color and see some specks in dark areas)
Set your frame advance to continuous by pressing the button on the left of the circle and setting it to the one that looks like multiple pictures.
And set your focus to "AI Servo" by pressing the "AF" button to the right of the circle and choosing "AF Servo".
Then shoot away.
Let me know how that works.
SOURCE: pinkish & blurry Canon Powershot A70 photos
CCD FAILURE CALL CANON SEE ADVISORY FOR FREE REPAIRS http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819 RATE ME WELL
SOURCE: Have a canon digital elph sd750. Pictures are now blurry.
You could have cracked the lens, damage the focus or a number of other things but the lens and focus are most likely. check your lens for scratches if there is none and no cracks take it to your nearest camera store or buy new good luck!
SOURCE: lens error restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
SOURCE: My photos look blurry not focused
check and make sure you do not have the soft focus turned on. that will make the pictures "soft" in focus or seem out of focus.
