SOURCE: CD ROM Boot
check in the device manager if ur cd drive is listed there or not, if not then u need to install the cd driver u canget the drivers and tthe firmware on the manufacturers website.
SOURCE: while booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
SOURCE: Toshiba latop 0201 #ide problem
IDE #0 is your primary hard drive.
Toshiba's System Errors indicate that the error 0201 Failure IDE #0
may be caused by bad contact points where the drive plugs into the laptop chassis. Toshiba recommends pulling the hard drive in and out several
times to clean up the male/female contact points.
Toshiba also said that if this doesn't work to contact one of their service centers for assistance.
The contact points solution rarely works, but is worth a try. Most likely, your hard drive failed and needs to be replaced.
SOURCE: Laptop HP NX9010 will not boot, Will go to bios, powers off after that.
It still sound like the hardrive,you can download a live cd of linix and try to see if it will run on linix,if so try reformatting the hardrive and reinstall windows,if you can get a copy of windows 98 and install that first 98 has a tendency to repair bad sectors of a harddrive,I have had many laptop drives not take xp untill I put 98 first.
SOURCE: cant install xp to dell c400 with external cd-rom
This is how I did it, you may or may not have the ability. A basic knowledge of Dos is necessary 1) I used another laptop but you could use an adapter to use the hard drive in a regular computer. 2)boot with a windows 98 boot disk, fdisk it to a fat32 partition, make the hard drive a system boot disk (format /s c:) 3) copy the i386 folder and all its contents from a full or full oem (not branded) disk to the laptop drive, also copy smartdrv and highmem.sys from the floppy (speeds thing up dramatically) and create a config.sys file with device=highmem.sys 4)physically install the hard drive back into the C400, boot to dos run smartdrv.exe, then go to the i386 folder and type winnt.exe (enter) wooo should work. MusslaChooda Pakichooda Nathuram Godse
