Already tried turning MIC on. It appears on, but nothing has changed
SOURCE: Mic not working
You need to press feature than the number 1 to turn on your mic. You can find support and get anything you may need from ldtsnj.com
SOURCE: mic ltie
If it used to work, and now suddenly it doesn't, likely the condenser microphone inside the phone is bad or has built up a static charge. If it used to work and you now here a buzz or humming sound instead of voice, you will need to discharge the microphone by disassembling the phone and shorting the two wires that go to the microphone (with the telephone unplugged!). I'm assuming you are referring to intercom calls and therefore the programming for handsfree outside line calls (memory block 4-29) doesn't have any bearing. If it used to work and the above procedure doesn't fix it, the phone is probably bad.
SOURCE: Mic not working.
in programming you need to turn memory block 4029 to on for your port number. port number is found by hitting feature 4 on your phone. ldtsnj.com
