Check that you have put the bobbin in the correct way. check that it is the correct bobbin for that machine and you could also check that the bobbin has been wound properly. If you load your bobbin up with different threads and not let if fill with only one thread you can have problems. Also clean out the bobbin area sometimes a bit of fluff can be caught in the bobbin area. cheers Dot
SOURCE: bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
SOURCE: Bobbin tangling
Sounds like the bobbin is spinning to fast or is winded to loose. Try adjusting the tension on the bobbin.
SOURCE: burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
SOURCE: top thread gets tangled in bobbin and won't pull up like
I'm new to sewing, and I had a similar problem where the top thread went all the way around the bobbin thingy and got stuck every time--solution: the bobbin case wasn't all the way in. The arm had to go in a slot at the top and it sort of snapped in, then it worked fine. Maybe it will help you!
