I try to update is but it is not turn on , plz help
SOURCE: when i turn on the philips gogear it says philips,gogear,updating and then it jams
This player has an issue that the latest firmware fixes, re: constant freezing during updating. If you can just get the computer to recognize the player, and load the firmware update then you should be fine. The firmware update should load when you go to the "Update" button on the latest Device Manager (the version of the Device Manager from Philips' website, not from the install CD).
If the computer is not recognizing the player, then try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
SOURCE: sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
SOURCE: Philips GoGear 2GB memory corruption
You have to do the "update" in the Philips Device Manager (make sure you are connected to the internet when you do) to repair the corruption:
Recovery
Mode for Philips' GoGear
Open
the Philips Device Manager (Start à
All Programs à Philips Digital
Audio Player à SAXXX à Philips Device Manager) and
click on the “Repair” tab. Then click on
the “Repair” button to start the repair process. Most of the time, when your player is in that
state, the Device Manager will not recognize that your GoGear is plugged
in. If this is the case: Disconnect the
player from the PC, and make sure the mp3 player is turned off. Hold in the
volume + button on the mp3 player, and reconnect the player to your pc while
holding in the volume + button. Continue holding the volume + for 10-15 seconds
until a "Found New Hardware Wizard" pops up. It should recover your
device if there isn't anything internally wrong with the player. Warning: this
procedure will result in your songs being erased off the player, so they will
have to be reloaded.
Philips
GoGear Firmware Upgrade
You
need to get the latest firmware upgrade from the Philips website:
1.
Go to www.philips.com/support
2.
Enter your country/language
3.
Enter your model # SA6045 or whatever
4.
Click on the link for your exact model # (the one w/o the "B" in it)
5.
Click on "Software & Drivers"
6.
Download the updated "Device/Firmware Manager"
7.
Once installed, open the Philips Device Manager
8.
Click on the "Update" tab, then the "Update" button (with
your mp3 player connected to the computer, of course)
9.
Your Mp3 players firmware will update automatically
If
you do not have the latest version of the Philips Device Manager installed (the
latest is the version from the Philips website), then clicking the
"Update" button will give you a false positive saying "The
firmware on your device is already up to date."
-Tha
Mp3 Doctor
SOURCE: Philips GoGear 2GB MP3/Video Player LOCKED ?
you have to look at the side and shift the lock button
SOURCE: need of philips gogear media converter
That same thing happend to me,No problem,just go to a Wal-Mart,and Find the place where you bout you're philips mp3 player,Now,get the one you bout and bring it to the closest cashier,and tell them you need to get the CD rom with the soft ware on it,because you currently lsot you're old one.They will replace it for free/small fine.i got a new one for free,in the small little white involope thing.so yeah.hope i helped.You're probebly not gonna find this software easy and availible as a free download online.;P
