I clicked all buttons but nothing happens. I also explored the menu like the drawer thingy.
Hi! and Welcome to Fixya!
There are two ways for your to change the language on the tv. You can follow the instruction below:
1. If you are familiar with the menu settings use the remote control to access it: press the MENU button > then select SETTINGS > select SETUP SETTINGS > select the Language > set to ENGLISH
2. If you are not familiar with the menu settings since it is written in Japanese language, you will need to reset the tv to factory default to set the Language to English. Turn ON tv first > press and hold down the UP Arrow button ( use remote control ) > while holding down the UP Arrow button, press the POWER button on the tv > tv turns off, wait until it turns on by itself > release the UP Arrow button.
Note: reset is successful when you see a welcome screen on the tv and ask you to select your Language. This is the Initial Setup, just follow the on-screen instruction
Let me know if this helps!
Most language options on electronics are found under "Settings"
Switch on
Menu
Settings
Preference
Language
Open Regional and Language Options by clicking the Start button , clickingControl Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
Click the Keyboards and Languages tab.
Under Display language, choose a language from the list, and then click OK.
I wanna change the language of my Sony Bravia KDL40V2500 from japanese to english and i can't do it. How can i?
