Question about Acer C720 Chromebook Gray 11.6" Notebook 1.4 GHz Intel Celeron 2955U, 4 GB DDR3, 16 GB SSD, Intel HD Graphics, Chrome OS, LED Backlight
When I turn it on, why does it go to demo mode?
My oven AZKM755 is locked in demo mode, how do I get it off demo pls.
To turn off Demo Mode:
1. Press SETTINGS 12 times. "Demo Mode" and "ON. Press (1) to OFF" will appear in the display text area.
2. Press the "1" keypad to change the Demonstration Mode setting to Off.
3. "OFF Selected" will scroll in the text area. Demo Mode has been turned Off.
If unable to access the DEMO setting, contact Whirlpool at: https://www.whirlpool.com/services/contact-us.html
Dec 23, 2017 | In Microwave Ovens
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
How to turn Mode Demo . Off on my Kitchenaid Walloven
Nov 11, 2016 | Car Audio & Video
How do I get unit out of demo mode...it is stuck and will not turn off demo mode
Here you go
Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the exercise bike is displayed in a store. If the demo mode is turned on,
the console will not turn off and the display will not
be reset when you finish exercising.
You can turn on or turn off the display demo mode.
From the settings menu, select Demo Mode. The
currently selected demo mode option will be
highlighted.
To turn on the demo mode, select On. To turn off
the demo mode, select Off.
Your manual is here.
http://www.sportsmith.net/images/product_support%5CProForm%5CPFEX013112%20-%20PROFORM%20LE%20TOUR%20DE%20FRANCE%20BIKE%5CPFEX01311.2-320509.pdf
Sep 19, 2015 | Proform Pro-Form Tour De France Spin Bike
No radio rception,player is in demo mode
1. Press and hold the SETUP button for at least 3
seconds.
2 Press the f UP or g DN button to select the
"DEMO" mode.
3 Press the BAND button to turn on or off the DEMO
mode.
Each press toggles between "DEMO ON" and "DEMO
OFF."
If no buttons are pressed 30 seconds after the DEMO
mode is turned ON. The DEMO mode then begins.
NOTE
The initial setting at the factory is "DEMO ON."
4 Press the SETUP button again to return to normal
operation
Nov 18, 2013 | Alpine CDM-7892R CD Player
How do i turn off demo mode
It is impossible to turn off demo mode as handsets in demo mode were specifically manufactured for demo mode. If you purchased the phone and it was in demo mode, please return it to the retailer and ask for a replacement.
Jun 23, 2013 | Nokia Lumia 920
My toshiba 36in crt tv's demo mode keeps turning it self on
Since I do not have your tv model number so can't be specific, check Demo mode option in Menu and turn it off. Some tvs have selection like Store/ Display and Home mode, store or display mode is demo mode so set tv on home mode to turn off demo mode.
Let me know model number of your tv if you have additional question.
Thanks.
Jul 22, 2010 | Toshiba Televison & Video
I have a 1996 magnavox tv that is in demo mode and you can only turn the tv off by unplugging the tv
Those older Magnavox sets had a demo mode available from the on screen menu. Go to the menu and disable the demo mode, that will fix the trouble. When in the demo mode you will have no control over your set by remote or front panel controls. You can still address the menu though to turn off the demo mode.
Apr 17, 2010 | Televison & Video
Turned off demo mode but it turns back on on its own
Viewing the demonstration (DEMO) mode
The DEMO mode automatically demonstrates several features of
your TV.
To start the DEMO mode:
1. Press MENU.
2. Press left or right button to highlight the SET UP menu.
3. Press up or down button to highlight DEMO.
4. Press left or right button to highlight START.
To stop the DEMO mode:
Press RECALL, EXIT, or POWER.
I hope this helps. Thanks for using fixya.
Jan 20, 2010 | Toshiba 36A43 36" TV
Demo mode on and system does not stay on
Try to put a cd in,this should kill the demo mode.
May 13, 2009 | Kenwood Sirius KDC-MP825 CD Player
Acer C720 Chromebook Gray 11.6" Notebook 1.4 GHz Intel Celeron 2955U, 4 GB DDR3, 16 GB SSD, Intel HD Graphics, Chrome OS, LED Backlight Logo
115 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
