you can just remove your laptop keyboard and replace it with new one from only opening some screw.
and if you want use temporary solution and use space bar temporary, then you can use " On-board Keyboard " for using all key which is on keyboard, Please Mark this Answer as HELPFUL.
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
move your carriage to right margin by using "tab" or "space bar". then press "margin release" and using "space bar" locate carriage where you want right margin to be, then press "right margin".
Hello
when you get to your message and you have typed a letter the button you would use to seperate the words is the # button.The # button stands as your space bar.
GOODLUCK
Simple! just click on the blank space beside the letters that you've typed in and press '0' or 'space' again.
Theres another option though, in message editing mode, select the icon with the pen and 'A' on the top left corner. Usually the first option of the 3. it'll change ur message editing mode to a QWERTY keypad.
The space bar key is connected tothe keyboard a little bit differently then any other key. There is a metal retainer connectedto the space bar key (on some keyboard models). Separate the retainer from thespace bar key with a flathead screwdriver. Install the retainer back inplace as it shown on the picture. You have to engage the retainer with thesmall hooks on the keyboard. Put the space bar key back inplace and gently press on it with fingers until it snaps back in place. That’s it. The space bar key isinstalled back in place and should work as before. If you still cannot fix yourkeyboard, then you’ll have to find a new oneand replace it. Pleas rate my solution on fixya if you are done.
Heyo, the fan needs to be cleaned. Your environment air may be the culprit...if that is the case, I am sure the space bar is doing that for the same reason. If you can afford to take it to the shop to have the shell taken off and cleaned properly, I would do it.
