Nintendo Expert
- Posted on Nov 18, 2015
Re: How should I respond to error code:51332 unable to...
- Change the security type in the Wii System Settings to WPA2 - PSK (AES) and test your Internet connection again. [How to]
- If the Wii detected the incorrect security type during the initial set-up, simply updating this setting within your existing Internet connection may resolve the issue.
- If this setting was already pre-selected as WPA2-PSK (AES) try the connection test again, prior to continuing to the next step.
- Check your network's settings to ensure you are using the correct wireless password. [How to]
- Make note of both the wireless password and security type. Both need to be entered correctly into the Wii Settings.
- Update the Security Setting within the Wii Internet Settings. [How to]
- Review closely to ensure both the security type and password match the information you located during step 3.
- Once you have entered the correct password or key into your system, try the connection test again. If the problem persists, keep reading this page.
- Power cycle your router and modem, and then try again. [How to]
- Ensure the wireless mode within your router's settings is compatible with the Wii console. [How to]
- The Wii console supports the 802.11g and 802.11b wireless formats (also labeled as "Up to 54Mbps" in some routers).
- If the router is using a 802.11n only ("Up to 300Mbps"), you will need to change this setting to allow the Wii to connect to your home network.
- Change your router's channel setting to 1 or 11. [How to]
- By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
for more help visit CBR Tech Solutions
