Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Will not eject any steam - Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Model sk410. how do I disassemble it?
Shark Steam & Spray Mop: How to Assemble - YouTube
? 1:27
https://www.youtube.com/watch?v=iH2NVXVA4-U
Sep 6, 2013 - Uploaded by Shark Cleaning
Assembling the Shark Steam & Spray Mop is easy. You'll ...Shark Steam & Spray Pro Mop: Using Steam and Spray Mode - Duration: 5:34. ... Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: 3:45.
Shark Steam & Spray Pro Mop: How to Assemble - YouTube
? 1:31
https://www.youtube.com/watch?v=I3thGlk2GdU
Assembling the Shark Steam & Spray Pro Mop is a breeze. ...Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: ...
Shark steam mop S3601 disassembly. - YouTube
? 3:38
https://www.youtube.com/watch?v=zq07GHhbJkI
Jan 07, 2016 | Shark Professional Steam and Spray Mop
How to get steam out Clogged h20 mop
Put vinegar in it and let it sit for several hours. Then turn it on to heat the vinegar. It should start to sputter and you may see some material ejected. This is good. Now dump out the vinegar and fill with water, make steam and let it push out any more material that caused the clog. You may have to do this several times in order to get the vinegar smell out.
Jun 28, 2014 | H2o TR220002 Steam Cleaner
My steam mop will not steam. the light comes on and it seems to heat up, but no steam comes out
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Oct 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop has water, but there is no steam....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
May 20, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop heats up but stopped putting out steam.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Mar 08, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop is spilling water out and not steaming.
Empty tank and fill with bottled spring water...
heatman101
Dec 05, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop does not create steam. 7 mos old
heatman101
a
My Hoover steam vac is not spraying the water. Instead it is ejecting 5 streams. This is a new probolem and in the several years I have used it I haven't had this problem before. I can find nothing in the...
There is a filter screen under the plastic cover below the brush indicator. If it is dirty clean it. The solution pump works off of vacuum. If this screen is dirty then the pump does not work correctly. Funny, the manual says nothing about this, only that the plugged screen can affect brush operation. I had the same problem with my solution and as soon as I cleaned the screen ......vola, the solution dispenses great again!
Dec 22, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Apr 19, 2008 | Scunci 52001 Handheld Steam Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
251 people viewed this question
Top Euro-Pro Vacuums Experts
Mark Bowens
Mark Bowens
Roxanne Jones
Level 1 Expert
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
