I replaced the cartridge because the older one wasn't working anymore. Now i continuously have the E14 error. What can I do? Please HELP! Thanks a lot!
SOURCE: Canon Pixma MP150 - Error code E7, light C flashing
Try removing cartridges and manually claening the heads with cleaning solution and cotton bud (q-tip) replace. Print. No luck? Now try uninstalling and reinstalling printer.
SOURCE: Canon pixma mp150 e5 error
had the same problem - would not recognise ink - would not scan - would not print --- phoned up canon help desk - no solutions for ink problem or scanner problem - cannon say printer will require servicing - so the nice man is emailing me return centres -(no idea of cost yet???) will be looking for a replacement 3 in 1 for future use -
SOURCE: canon mp150 pixma printer error e5
dear warenout
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
SOURCE: Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
SOURCE: My Canon Pixma MP150 printer LCD shows error
It is problem any hardware is not work properly.If you are a technician please service your printer properly.Clean all surface, blowing it.when you show E2 press black or color key
