Question about Cellular Innovations Radio Communications
I have an over the head blue tooth and lost the manual. I haven't used it in a while & am having a problem getting my phone to pair with it (or vice versa). What should I do?
6ya staff
SOURCE:
Anonymous
SOURCE: pairing a samsung wep200 headset to a samsung blackjack
Great solution. I threw away my instructions. The key is the 0000 pass key!
Posted on Jul 25, 2007
Anonymous
SOURCE: Blue tooth pass code
Typical pairing code for PLT Voyager 510 is 0000
Posted on Jan 03, 2008
Anonymous
  • 3 Answers
SOURCE: I have a H350 Blue tooth, I have a new phone, I forgot passkey.
Pin or pass code should be 0000.
Posted on Mar 22, 2009
Anonymous
  • 7 Answers
SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
Posted on Sep 22, 2009
TO Lady
  • 638 Answers
SOURCE: Jabra OTE3 won't pair with Verzon LG phone. How do
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Posted on Jan 05, 2010
CANNOT GET TO PAIR says it is but is not connected
Hi, It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps.
Thanks for using fixya.....
Nov 29, 2010 | Jabra Bluetooth Headset with Adjustable...
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
I just bought a samsung soltice phone and I have a scala-600 bluetooth but I cant seem to get them to connect have any suggestions and I have used a bluetooth befor.
Take care.
Sep 12, 2010 | Cell Phones
I have lost my Bluetooth manual and have switched phones. How do I reprogram it to the new phone?
Hi,very easy.It's just the same way you paired the blue tooth with the phone.Dothe same with the new phone are you are done.
Have a nice day.
Sep 01, 2010 | Cell Phones
How to connect sony ericsion w395 via blue tooth
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
Can not find nymber to pair my blue tooth bk600 to cell phone
disconnect it on the phone and repair. it will ask for a new security code....
Jun 18, 2009 | Pantech Matrix Cell Phone
How to pair Nokia 6250 with blue tooth device
the nokia 6250 hasn't got bluetooth ... sorry
Jun 13, 2009 | Nokia 6250 Cellular Phone
The phone with which my H350 Motorola wireless head set was paired , got lost. How to pair the head set with my new HTC phone
you have to hold the button on the top till the blue stays on then go in your phone to the blue tooth settings and search for the device it should find it and be paired again
Nov 27, 2008 | Motorola Mobility H350 Wireless Headset
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Radio Communications Logo
70 people viewed this question
Top Cellular Innovations Radio Communications Experts
Anthony Ward
Anthony Ward
Marvin
Marvin
Are you a Cellular Innovations Radio Communication Expert? Answer questions, earn points and help others
