Baumatic MEGAWDSS Front Load Washer / Dryer Logo
A
Anonymous Posted on Mar 31, 2017
Why has it stopped mid-cycle and won't do anything?
I set my washing machine to run a programme that should have taken well over an hour. However, when I checked up on it the washer had apparently progressed through the full cycle very quickly. The programmme dial showed that the cycle had completed, and allowed me to open the door, but when I did there was still water inside. I tried running the programme again, but this time after the drum had stopped filling, nothing happened. Now I can't get any programme to function and have had to remove my soaking clothes and catch the flood of water in a bucket. What could be causing this? I have a feeling that it is something to do with the filter or drainage pipe, but I'm not sure. Thanks.
5 Related Answers
A
Anonymous
  • Posted on May 14, 2007
SOURCE: Stains on clothes
Have you tried Calgon to get rid of limescale deposits? Also have you used any laundry bleach at any point, because it stays in the machine for ages and clothes come out with faded patches and bleach marks for weeks afterwards.
A
Anonymous
  • Posted on Jul 11, 2007
SOURCE: baumatic btwm4 washing machine wont rinse and empty
If it wont empty its either a blocked pump/or filter. If it won't move on, heating element
Anonymous
  • 734 Answers
  • Posted on Dec 12, 2008
SOURCE: Leaking Machine from underneath
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Anonymous
  • Posted on Dec 29, 2008
SOURCE: Baumatic MEGA WDSS washing machine
go onto manualtree.com type baumatic megawdss washing machine, if this does not bring anything up scroll down until you see it in the listings. type in the code it asks for (this will be supplied underneath, its just to stop cumputers auto logging) and then download then manual. good luck
Anonymous
  • 31 Answers
  • Posted on Oct 11, 2009
SOURCE: My Baumatic MEGA6SS washer is still full of water
sounds like your drain pump is not working. that will be the case if there is no noise. if you hear something when it should be draining, check the screen to be sure it's not plugged.
Haier hwmp95tl washer
Try unplugging for one hour or so; machine may re-set.
Balay TW5512 cycle problem
is the heater working? Re: Jeff
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
1helpful
Stopping mid cycle, not taking softner, doing a
OKAY.....Could be cold water not entering the machine , due to turned off. or faulty valve coil not too expensive to fix...
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
Zunussi zwf1437w Keeps stopping during programmes
This sounds like a drainage problem. First thing is to check the filter behind the flap on front of machine.
Please post back your findings for further assistance.
Thankyou for using Fixya.
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
AM 110 washing machine - light not coming on and would not respond to programme
It sounds to me like you may have blown a fuse or tripped a breaker. If your washer uses a regular 110 volt outlet, you can try plugging in another electrical appliance of some sort to see if there is any power in the outlet. The only other possibility I can think of right now is possibly a fuse inside the machine.
Top Baumatic Washing Machines Experts
ZJ Limited
ZJ Limited
vince
NOEL
NOEL
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
